Home Water Filter System Under The Sink
Just like to share what i found and had bought for home water filter system.
after doing some intensive research over 2 weeks. i decide for APEC 5 stage reverse osmosis under sink water filter. :thumbs up:
i was torn between using expresswater or APEC. But from reviews both in amazon and outside, it seemed APEC is the preferred model. but expresswater comes cheaper and with extra water filter ! :thumbs up:
I have left the UV light option out as i think ours is considered city water that is already well treated and besides i do not want complication of getting the wiring for uv light and if anything wrong i gotta fix the uv.
however, since i cannot find a company here selling, i will have to diy install. i manage to get a plumber who say he can install but regarding the kitchen top faucet, he need my kitchen contractor to install the faucet, the rest he can do. so YES! :thumbs up:
i bought from amazon and ship via my package forwarder. Yes! :thumbs up:
APEC Water Essence ROES-50 system delivers high quality reverse osmosis drinking water at an affordable price. This complete 5-stage water filter system is made from high caliber components to offer exceptional contaminant rejection rates and long-lasting, reliable performance. Designed and built in the USA, the Essence was developed based off our 17 years of experience in RO design and production- a lineage of proven success. We are proud to offer this incredibly efficient and productive RO system that will provide you and your family with trouble-free, high quality drinking water for many years to come! The ROES-50 system comes with a 30-day money back return guarantee and a one-year limited warranty. With our manufacturing facility based in Southern California, APEC Water is committed to supporting its large customer base by stocking and supplying all replacement and service parts to ensure high performance and longevity. In addition, the manufacturer has in house WQA (Water Quality Association) certified water specialists that provide excellent & Free technical support for the entire lifespan of the system.
System Overview and Specification
  • 1st Stage: Sediment removal 5 micron 10 inch filter —removes dust, particles, and rust. Protects and extends the life of the membrane and system.
  • 2nd Stage: Carbon block 10 micron 10 inch filter —gets rid of unpleasant chlorine, tastes, odors, cloudiness and colors. Also removes VOCs and other common chemicals from the water.
  • 3rd Stage: Carbon block 10 micron 10 inch filter —gets rid of unpleasant chlorine, tastes, odors, cloudiness and colors. Also removes VOCs and other common chemicals from the water.
  • 4th Stage: High Rejection TFC reverse osmosis membrane. Removes a wide variety of contaminants including arsenic, bacteria, chlorine, lead, fluoride, chromium, radium and more.
  • 5th Stage: Coconut Shell Refining Carbon 10 inch filter —removes any possible residual taste from the tank.
  • Smart and automatic design shuts of system automatically when tank is full without wasting any water.
  • Treats all types of water including tap water, well water, hard and soft water at variable pressures and pH extremes.
  • Low maintenance – just change 3 Essence pre-filters once every 6-12 months.
  • Industry standard design and parts offer system versatility, compatibility & upgradability.
  • Heavy-Duty, solid construction for many years of noise free operation
  • Do-It-Yourself (DIY) system design is easy to install, troubleshoot & maintain
  • Uses same filtration technology as bottled water companies and eliminates the need for bottled water, in return less plastic waste and pollution.
  • APEC Water does not distribute or sell our products to any 3rd party sellers on Amazon. Please purchase genuine APEC Water products from Amazon or APEC Water directly for authenticity.
This is the expresswater
Edited by Relacker
  • 2 months later...
manage to get my ID to help me install the APEC water filter. :wub::yamseng: thanks to the plumber who complied and help out.
Installation is quite simple but the drainage point if you are doing connection to drain pipe need be low than filter. Also if you have a ceramic sink like us, you need to be very careful to ensure the supplier help you drill a hole for the filter tap faucet as ceramic drilling can cause cracks. no prob if sink is metallic
Edited by Relacker
Around $500.( inc shipping) This is 5 stage filter. I was considering 6 stage (with uv light) but decided against it bcos electrical point below the sink i find too risky and complicated as i initially also dun know if it can be easily installed. (Although online buyers all give good ratings and say easy to install on feedback page)
Edited by Relacker
wow a RO system for normal usage the waste water is going to a lot if not wrong?
Possible to install on a hot and cold tap, eg hot inlet for tap water and cold inlet for RO water? So the additional tap hole can be used for built in detergent dispenser.
The system really quite smart. It will store the filtered water into the pressurised tank. And stop once the tank it fills up.
no, its does not "waste" any water, a RO system uses water to clean itself and wash away impurities. It's like a lot of other water-using appliances. We use water to wash clothes, to wash dishes, to wash cars, to flush toilets.
A reverse osmosis unit uses more water in its operation than you actually consume,yes. but it doesn't use enough that you'll notice it on your water bill.
It uses water only while it's filling its storage tank. When the tank is full, the whole unit shuts down and no water runs to drain.
In terms of expense, it's like a couple or three extra toilet flushes a day. it will be even less if you do not use the water for washing but just drinking.
I think the APEC is really value even after shipping. A 3M 5stage filter cost 2.3k to buy and install. Even hyflux does not provide 5 stage RO filter and it cost already 1.xxk for 3 stage
Edited by Relacker
actually if its metallic sink, drilling more holes is not issue to install mmore taps. But for ceramic sink, usually they have already designated 1 or 2 more positions where you can drill for extra taps, but drilling you gotta ask if they provide if not can get ID to help(but they will tell u if crack they not responsible)
otherwise some can install on the solid surface top or even the kompac plus top.
what started me to search for a serious home water filter was a few yrs ago, i kinda itchy hands and went to buy a $2 filter for tap from daiso. after few weeks i start to realise the water filter changing colour to slight brownish from white,. i mean even for cheap simple filter like this it already collected some substance, i did not bother to find out what they are but for sure i do not want these in me. i continue to use the $2 filter as min form of filtration though, changing it every few months.
additionally, i find there are harmful effects of flourine despite what ppl say about tooth decay prevention etc
thats when i realise there actually different levels to what is good clean drinkable water, i know of friends who solely buy bottled water just for drinking. i know i may get stick for this but to each his own.
And i have been drinking this kinda water for my whole life, not that anything happen to me.
So now got opportunity to install a good filter thats when i start searching for one.
Edited by Relacker
  • 8 months later...
hi bro,
i'm interested in getting the same APEC water filter as you, just want to check how is it so far?
how long it takes for it to deliver to you? need to change filter every year?
Interested in the APEC system...can pm me the link to purchase? May I know what size is the faucet? Thanks.
Raymond
  • 5 months later...
Hihi,
I am following exactly your path with a similar stone sink and wanting to drill a hole for the water filter... I couldn't find any contractor willing to drill a hole or those that did say no guarantee on cracks ! How did you find such a contact? Did they just use a normal drill bit? The stone never crack?
Installation is quite simple but the drainage point if you are doing connection to drain pipe need be low than filter. Also if you have a ceramic double sink like us, you need to be very careful to ensure the supplier help you drill a hole for the filter tap faucet as ceramic drilling can cause cracks. no prob if sink is metallic
5
Wow, Great idea to use the dead space under the sink.
How much the installation cost?
Do you habe any idea how long it will last?
@Relacker
How is your Water Filter system now? since this is about 2 years now
Still good and reliable? how many times have u since purchase new filters
