Is This Quotation Okay? (Resale 4A)
Dear all,
Can trouble you guys to advise if this quotation is okay?
1) General & Masonry Works
1.1 Supply labour and materials to overlay 3 bedrooms + 1 living room including skirting. Tiles capped at $3.2psf (Advise to keep tiles to save cost)
Living room and 3 bedroom tiles still in good condition
$ 8,700.00
1.2 Supply labour and materials to erect wall to replace sliding door for kitchen area
$ 735.00
1.3 Supply labour and materials to hack and lay new kitchen wall tiles. Tiles capped at $3.2psf
$ 4,295.00
1.4 Supply labour and materials to hack and lay new kitchen floor tiles. Tiles capped at $3.2psf
$ 2,035.00
1.5 Supply labour and materials to hack and lay service balcony wall tiles. Tiles capped at $3.2psf. Including construction wall to decrease height of Toilet louver window
$ 2,825.00
1.5 Supply labour and materials to hack and lay service balcony floor tiles. Tiles capped at $3.2psf
$ 1,360.00
1.6 Supply labour and materials to hack and lay common toilet wall & floor tiles Tiles capped at $3.2psf. Water proofing membrane provided FOC
$ 4,650.00
1.7 Supply labour and materials to hack and lay Master toilet wall & floor tiles Tiles capped at $3.2psf. Water proofing membrane provided FOC
$ 4,650.00
1.8 Supply labour and materials to lay new copper pipes and water points including installation of all sanitary fittings. Cost of Sanitary fittings born by owner
$ 1,800.00
1.9 Supply labour and materials to repaint entire 4rm flat unit with Nippon Vinilex 5000 series. No limitation of colours
$ 1,800.00
1.10 Supply labour and materials to apply Water proofing membrane for sanitary stack in kitchen area
$ 360.00
1.11 Supply and install plaster board partition in Master bedroom area $ 450.00
2) Carpentry Works
2.1 Supply and install open door wardrobe in master bedroom Est 107" x 103" (h)
$ 2,020.00
2.2 Supply and install bay window cabinet Est 93" x 12" x33.5"(h)
$ 910.00
2.4 Supply and install Bottom only kitchen cabinet on left side. Est. 85"x 23.6"
$ 995.00
2.7 Option 3:
Supply and install Kompac Top for left side cabinet 85"
$900.00
2.8 Supply and install Top and Btm Kitchen Cabinet with Side panel Box up Est. 139" x 103"(h)
$ 2,240.00
3.1 Option 3:
Supply and install Kompac Top for 139" Kitchen top
$1,524.00
3.2 Supply labour to dismantle and dispose Kitchen Cabinets and island cabinet,
Fishtank cabinet, Sliding Glass door, Wardrobe in master bed room, Build in cabinet in common toilet w/ mirror.
$ 1,800.00
3) Windows and window grills
3.1 Supply and install Kitchen 3 panel sliding window Est. 69" x 42"
Advised to change to sliding instead of casement for easy access to hang cloths
$ 380.00
3.4 Option 3:
Supply and replace glass for Master bedroom and 2nd bedroom windows
$550.00
3.5 Supply and install Louver windows for master room Toilet Est. 46" x 22"
$ 320.00
3.6 Supply and install Louver windows for common Toilet
$ 320.00
3.8 Supply and replace glass for Living room and 3rd bedroom windows
$ 550.00
3.9 Supply and replace Louver Glass for dining area windows
$ 100.00
3.10 Supply labour and materials to dismantle rod iron window grills and provide new powder coating paint
$ 650.00
4) Doors
4.1 Supply and install Veneer Solid Main door double leaf
Est. Big leaf - 82" x 34" Small leaf - 82" x 10"
With stainless steel lever and standard lock set
$ 1,050.00
4.2 Supply and install 3x Semi-Solid Veneer door for bedrooms @ $460Ea Est. 82" x 32" Single leaf door with stainless steel lever and standard lockset
$ 1,380.00
4.3 Supply and install 1x Solid Veneer door for bedrooms@ $500Ea Size same as above mentioned doors
$ 500.00
4.4 Supply and install 2x Toilet PVC Bifold Foam Door @ $650Ea $ 1,300.00
4.5 Supply and install Sliding barn door 35 6/8" x 83" x 1 3/8" $ 850.00
Total: $52k+++
He then gave me a discount of $2.8k
Thanks!
Edited by kei66
Hi kei66,
I think your quotation is quite reasonable for an ID.
I'm also interested in getting a quote from your ID to compare. Mind sending me his contact too? I have search for many IDs and so far I have shortlisted a few. One of my IDs gave me a very good price. My kitchen cabinet of 26ft top and bottom, he quoted me $3,000 only, which is the cheapest so far. And the Quartz he quoted me $2,600. I'm still considering though.
  • 5 weeks later...
Look ok to me. mind sharing the Contractor who qoute this?
What material he use?compressed wood?you need ask your contractor to make it clear.
