brooklynnygarage
My garage door won't open? What can I do?
Sometimes, people unplug their power source and then wonder why their garage door opener fails to work. Sounds ridiculous, I know, but it does happen. Make sure that your garage door opener is plugged into a working outlet. Outlets sometimes go out without warning, so you can check to see if the outlet is working by plugging another working electronic device into it. Also, check your circuit breaker, fuse, or GFCI.
