Motor got stuck
I've got a motor issue. My motor stopped working tonight. I tried to replace the fuse but that was not it. When I take the cover off of the motor it works fine. I think there is an obstruction in the front valve. Could this be the culprit? I cannot get a look through the PVC piping that makes up the valve going to the outside. I tried from the outside and it feels like there is an obstruction right toward the end. If that is the culprit I will need to cut the pipe to get to it. I need to fix this really fast as I don't have much water stored in my tank. For that, I am searching for an emergency service. Do you know if there is any who can fix this ASAP? My friend suggested emergency plumbing services in Calgary
