My Hdb masterbedroom current flooring is parquet. Below the parquet is ceramic tiles. One section of the room the ceramic tiles broken and pop out causing the parquet to pop up.
Did enquire with some contractor but no one wants to repair the broken section.
Most contractor suggest hacking the entire room cement screed and lay new vinyl. Not an issue but at this point budget very tight. Any suggestion or contractor to recommend.
Thanks
Tiles pop out are due to poor workmanship. If one section of the tiles has popped out, the rest of the tiles may pop out as well. Your contractors are wary that if they just repair the broken part, the rest of the tiles will pop out in the repair process.
My advise is to remove all the tiles first. No point just to repair one part and then later on another parts pop out. Better tackle the root cause of the problem once and for all.
Edited by KFC1189
