applek24
Overlaying Or Plastering ?
anyone can advise on overlaying of wall tile ?
There is forum talking about it, under Plaster Kitchen Wall Tiles? Possible?, Cut cost on hacking and retiling by plastering
http://www.renotalk.com/forum/index.php?showtopic=5996.
It would be better not to overlay of wall tiles, fear of next time the tiles pop out. You need to check the existing wall tiles to ensure not hollow pieces.
Plastering another getting popular choice. you can browse at blog chat to find out.
I hacked my kitchen wall tiles, plaster and paint . Only kitchen cabinet area have wall tiles.
Contractor: Action Design
Reno Status: Started 1st June 07
Reno Progress photograph: http://1000miles.multiply.com/photos/album/16
Edited by 1000miles
One of the ID also suggest to me that only the cooking area have wall tile, the rest ask me ti plaster. How much did you spend ?
Hi Applek24, hope you have got your ans to your ques. Its seems that there are more advises against plastering over wall tiles. The bottom line is.. just how much do you think it will cost you to hack off the wall tiles? The contractor will still charge you the cement screeding. If you hack and then plaster, it wont cost you too much, and most important, you wont have a lingering doubt whether the tiles will pop, plaster peel or area getting narrower. Think about it.
thanks for your advise. will see how much will it cost me for that.
apple, i am hacking off all the wall tiles and plastering over. and will only tile up the cooking area. small area only. but then i am going for open kitchen intergrated with dining room. so thatz why i opted to plaster the kitchen walls so that it will look like part of the dining room.
i too, feel that it is not good to overlay.
oh yeah. and when we finally hacked the kitchen we realised it was ALREADY overlaid. haha.
Since I'm tiling the cabinet side, my ID advised me to tile everything since the cost removing existing tile at the opposite side of the cabinet + plastering, cost quite "near" to fully tile. Cost difference maybe like ~$300.
Full tile sounds more durable and yeah, you can ask your ID not to tile at the cabinet side since it's not exposed and you can save a bit from there.
Hi apple,
i also did plastering for my kitchen wall. But make sure you use chemical mixed with cement the layer thickness would be roughly about 0.5mm only so not much diff. Than afterthat paint it with sealer before applying emulsion paint. So far it looks okay no cracks maybe it's noly 1month old. For me the cabinet side do not have tiles also but im putting painted glass on the open area looked more modern and also easy to wipe with soft cloth.
Hi apple,
LemonTea, can help explain the bolded ones. Thanks.
Hi andrew, the wall in between the top and bottom cabinet whereby you put your SS backing. I did not install tiles nor the SS backing but i put up painted glass on this side of the wall. Any oil stained etc can be easily cleaned using a soft material cloth.
