Plumbing and heater questions
Hi all..
Just got the keys to my resale hdb. It comes with a storage heater installed in the common bathroom supplying hot water to both common and master bath.
The switch that control the heater is outside the common bathroom.
Can i change the heater switch to be in master bed room instead and disconnect the common bath from the storage heater? then will install an  instant heater in the common bath with the switch outside the common bath. As this is meant for tenants. Will this work... thanks !
  • 4 months later...
Hey buddy. I think you shouldn't have any problems with this. When I bought the shut-off valve here , which controls the flow of liquid to myself for the backyard, I connected the heating heater to the system. The only caveat is that I had to buy a voltage stabilizer.
