zfuyuan
House Reading
Hi Mr Chong,
Please help to advise on our house layout.
Compass readings are:
A. 218-220 (Step 1)
B. 218-220 (Step 1)
C. 142-144 (Step 2)
D. 312-314 (Step 3)
Our birth year are the same: 1982
Will PM you our birth date time for your kind reference.
Thank you.
housean7.th.jpgFloorplan
areavu0.th.jpgNeighbouring Flats
21072008031gx7.th.jpgStaircase
21072008032gr8.th.jpgPic taken out from my main door
21072008033mx2.th.jpgPic from balcony
Edited by zfuyuan
Hi Mr Chong,
A. 218-220 (Step 1)
B. 218-220 (Step 1)
C. 142-144 (Step 2)
D. 312-314 (Step 3)
Thank you.
Hello
Can you take a pic of the left and right side of your main door?
Zoom in and take a pic of your opposite neighbor's "Fu".
Are you staying below 5 floors or above?
I need you to retake the readings again. Give an exact reading. Not a spread of 2 degrees. Do you have a good compass?
On the left is the staircase.
On the right is a wall.
Will take pics of them.
Will do.
Yes. 8th floor.
Will give an exact reading for you.
Thanks, Mr Chong. I will take the readings and pics and post them here again.
Hi Mr Chong,
Here are the updated details:
Compass readings:
A. 225 (Step 1)
B. 220 (Step 1)
C. 143 (Step 2)
D. 311 (Step 3)
Hello
On 9 Aug 08 8.30am, go and place 2 plants outside your main door. On the left beside the stairs, use a big money plant. On the right, remove all the tiles and debris. Plant a dragon bone plant beside. It must be shorter than the money plant.
You can ignore your neighbor's "fu". I'll check for you the rest another day.
Hi Mr Chong,
Thank you so much for your reply.
1. I am currently on a holiday trip and will only be back on 10th Aug 08.
Is there any other date I can place the plants?
2. I have yet to start my renovation. (planning to start after lunar 7 month)
Is it ok if the plants are shifted further away from the main door during the renovation?
3. Is dragon bone plant referring a cactus as shown in the picture below?
So sorry to inconvenience u.
Thank you.
Edited by zfuyuan
Hi Mr Chong,
Yes, this is the plant.
Then post again after your reno.
Hi Mr Chong,
1) We would like to ask for your advise regarding our Dong Tu date/time and its procedures.
2) This is the latest floorplan:
- The common kitchen toilet door is shifted nearer to the windows.
Is the overall layout ok to proceed?
So sorry to inconvenience u again.
Thank you.
Edited by zfuyuan
Hi Mr Chong,
Thank you.
Hello
For your dong tu date, you got to pm your DOB to me again. Already deleted.
In the mbr, at the toilet entrance, place brown pebbles there. More.
Make sure your washing machine is not overlapping into the stove.
Hi Mr Chong,
Was unable to PM your mailbox. Will be writing it down here temporary.
His: 07 Aug 1982,
Hers: 25 Aug 1982,
Like to clarify the placements of the pebbles. Should they be place:
1) infront of the toilet door (in the mbr)
2) behind the toilet door (in the toilet)
(From your sentence, it seems like ans 1, but i am checking again to double confirm)
Is it ok if I switch the fridge with washing machine? (Meaning that the overlapping items are fridge and stove)
Thank you.
Edited by Mr Chong
Hi Mr Chong,
His: 07 Aug 1982,
Hers: 25 Aug 1982,
Dong tu date: 17 0ct 08 12:08 pm
Both also can. In the toilet, you won't kick it so easily. In the mbr is preferred.
Fridge and washing machine the same. Try to do some adjustment by shifting.
Edited by Mr Chong
Hi Mr Chong.
Thank you for the date.
Based on this 動土 article, is the procedure that we should follow as documented?
祭拜對象: 土地神
供 品: 牲禮、水果、糕餅、鮮花、茶酒
祭拜程序: 擺上供品→點蠟燭→獻茶、酒→焚香(三柱香)祭拜並祈求土地神保佑工程順利→香燒到約剩三分之一時,雙手捧金紙拜神明→燒壽金、刈金、福金→將酒灑於紙灰上→撤供品→舉行奠基儀式。
Hope you can advise us regarding Dong Tu procedures.
Ok, will shift the stove to prevent overlapping.
Thank you.
祭拜對象: 土地神
供 品: 牲禮、水果、糕餅、鮮花、茶酒
Hello
Dong Tu procedures (if I didn't remember wrongly) has been discussed some where in this forum or under 'geomancy' column. In traditional procedures, the focus is on the earth god. If you're interested, you can just follow the above or any offerings to the earth god will do. Rather than the above, incense is the best.
You can also do away all the above and follow my instructions. At the above given date and time, get the reno worker to break (standing at main door looking out on the left) a chunk of your interior wall approx 3 feet away. Good enough. (Plaster back after reno)
