Is This Quote Reasonable For 4 Rm Standard Flat?
Have about 3 quotations on hand and this ID is the 2nd lowest quote we got...feel very comfortable with the ID and pleased with his attitude and service so far though what he quoted is over our budget of 20K..thought of confirming with him soon but need advise on whether the quote is reasonable for a 4 rm flat...
Living/Dining
1. Supply and lay 600mm x 600mm homogeneous tiles c/w skirting incl store
2. Supply and construct false ceiling c/w alcove light pelmet
3. Design and fabricate 5ft half-height shoe cabinet in laminate finish
Kitchen
1. Provide labour hack new entrance
2. Set up existing entrance using 63mm hollow block c/w patch smooth
3. Repair and patch damaged wall tiles after hacking works
4. Construct fridge and washing machine base
5. Construct cabinet mortar base
6. Design and fabricate 13ft bottom and 16.5ft top cabinet in laminate finish
7. Supply and install 3ft top hung sliding door & 1 fix panel in clear tempered glass
8. Supply and install black granite worktop c/w backsplash
9. Supply and install coloured glass backing
Master Bedroom
1. Supply and install laminated flooring c/w skirting
2. Design and fabricate 6ft sliding wardrobe in laminate finish c/w storage drawers
3. Design and fabricate 3ft low storage cabinet in laminate finish
4. Design and fabricate 5ft study table in laminate finish c/w storage drawers
5. Design and fabricate 5ft storage cabinet in laminate finish
6. Fabricate 9ft wall mounted ledge in laminate finish
Master Bath/Common Bath
1. Supply and install 10mm clear tempered glass shower screen
Bedroom 2
2. Design and fabricate 5ft sliding wardrobe in laminate finish c/w storage drawers
3. Design and fabricate 3ft study table c/w top hung storage cabinet
Bedroom 3
Plumbing Works
Supply labour and material to install:
1 x storage heater
1 x kitchen sink
2 sets of bath accessories
Miscellaneous
1. Supply and paint whole unit walls and ceiling in ICI/Nippon paint
2. Provide general cleaning services before handing over
3. Provide cardboard protection to flooring
Total costs: $25K
Living/Dining
Kitchen
Master Bedroom
Bedroom 2
Bedroom 3
Plumbing Works
1 x storage heater
1 x kitchen sink
Miscellaneous
Total costs: $25K
Sound reasonable as you got lots of capentry works.
Any other feedbacks?? Quote of 25K is excluding electrical works which is estimated at $1.5K...
i have also sourced quotes from a contractor which is highly recommended here and the quote comes up to about the same with above ID...in this case, a ID will be better since ID will do the 3D drawings, color coordination etc??
Hi i'm new here.
Would like to know typically a quote from ID include general works and flooring wet works?
Hi icegal,
They are all included in your quote as well?
Living/Dining
Kitchen
Master Bedroom
Bedroom 2
Bedroom 3
Plumbing Works
1 x storage heater
1 x kitchen sink
Miscellaneous
Total costs: $25K
Hi icegal,
Sounds reasonable to me too. Jus tat u need to clarify the tiles P.S.F, no of colors for painting, acid wash, & clearing of debris & haulage. Most importantly, ask if theres any more hidden costs u shd b aware of.
L3x
Hey icegal,
e pricing is reasonable.
Additional pts u might wana find out, i'd highlite in red, for ur reference.
Living/Dining
- tiles price range u can choose?
eg. tile priced at $2.80 psf, if u select a tile which cost $3.80psf, then u gota top-up $1.00 x e amount of tile e ID gona order.
Kitchen
- cabinet/drawers doors c/w ABS trimming?
- if not, wats e finishes at e edges of e doors?
- types of handles?
- dish rack?
- cutlery tray?
- type of hinges?
Master Bedroom
- brand of laminate flooring?
eg. supreme
- frame or frameless
Plumbing Works
1 x storage heater
1 x kitchen sink
- includes e storage heater, kitchen sink & bathroom accessories?
- extension of water supply piping for kit sink & washin machine?
- extension of water drainage piping from kit sink & washin machine?
- inlets & outlets pts?
- gas piping?
Miscellaneous
- haulage?
- clearing of debris?
- once hacking is involved, gota apply permit. If needs P.E. endorsement, how much P.E. fees u gona bear?
- instal tap at kit sink?
- instal hood & hob
Total costs: $25K
- 7% GST?
Edited by jaCKY777
Mine hse was quoted in total at $40k for a 4 rm resale flat, reasonable?
MAIN ENTRANCE
To supply and install 1 no. of designer's door c/w laminated frosted glass
LIVING HALL
To fabricate and install full height Shoe cabinet in selected laminate finishes ( 6 ft )
To fabeicate and install wall panel c/w cantilever TV console and 3 nos. of drawers in selected laminate finishes(L=2700mm X W=400mm X H=300mm)
To suuply and install false ceiling c/w recess light
To supply 4 nos. of pole divider in selected laminate finishes
BEDROOM 2 ( GUEST ROOM )
To supply and install simple cornice
BEDROOM 3 ( STUDY ROOM )
MASTER BEDROOM
To fabricate and install TV wall panel in selected laminate finishes ( 3 ft )
To supply and install Bed head wall panel c/w 2 nos. of side table
To supply and install false ceiling and recess light
MASTER TOILET
To supply and lay ceramic wall tiles ( Tiles @$2.50 p.s.f. )
To supply and lay ceramic floor tiles c/w water-proofing ( Tiles @$2.50p.s.f.)
To supply and install frameless tempered frosted glass shower screen
To supply and install frosted glass swing door ( 3 ft )
To box-up water pipe using cornice board with recess light
To fabricate and install wall hung vanity cabinet c/w frosted glass door and aluminium frame and solid surface top ( 2 ft )
To supply and install frameless wall mirror ( 4 ft X 3 ft )
To supply and install Naco window ( 1 set )
COMMON TOILET
To supply and install PWC Aluminium swing door c/w acrylic panel
To supply and install PWC aluminium 3 panel of shower screen ( 5 ft )( Include the kerb )
To supply and install exhaust fan with fixed glass panel (Brand :KDK@$140 )
KITCHEN
To supply and lay ceramic wall tiles on exposed area ( est.260 sq ft. )
( Include supply and lay moasic tiles at Cooker & Sink area )
( Tile @$2.50 p.s.f. )
To supply and lay ceramic/Homogeneous flooring c/w water-proofing
( Tiles @ $2.50 p.s.f. )
To construct kitchen cabinet, washing machine and fridge base
To supply and install Bottom kitchen cabinets in selected laminate
finishes ( 18 ft ) c/w
a) Stainless steel Dish-Rack b) Cultery tray c) 4 nos. of drawers
To supply and install solid surface top ( 15 ft )
To supply and install 1 no. of stainless steel rubbish chute ( Flat type )
Construct kitchen wall with half tempered glass & slinding door
PLUMBING WORK
To supply labour to install 2 nos. of W.C. , 2 nos. of Basin, 1 no. of Sink,
1 no. of Washining machine pointt, 1 no. of storage heater and toilet
accessories
To supply & install stainless steel water pipe at kitchen & 2 toilet
( Inlcude 2 nos. of Hot and Cold points )
OTHERS WORK
To paint whole house with ICI/NIPPON emulsion paint
To supply and lay 600mm X 600mm China homogeneous tiles c/w skirting
****/Dining and 3 Bedrooms ( Tiles @$3.00 p.s.f.)
HACKING WORK
To hack existing wall & floor tiles at 2 nos. of toilet and kitchen, hack
exsiting floor tiles ****/Dining & 3 Bedrooms and dismentle existing
kitchen cabinet ( Include Sand & Hauluage Charges )
Acid washing for whole house
ELECTRICAL WORK
To supply and install electrical work for whole house ( As per attach list )
OTHER WORK
To supply and install Natural casement window and grilles at Balcony
To Relocate & add on a fan coil in the living hall
Hey icegal,
Living/Dining
eg. tile priced at $2.80 psf, if u select a tile which cost $3.80psf, then u gota top-up $1.00 x e amount of tile e ID gona order. --> $3 - $3.50 psf
Kitchen
- cabinet/drawers doors c/w ABS trimming? - no ABS trimming
- if not, wats e finishes at e edges of e doors? - ID explained but me still nt too sure
- types of handles? -
- dish rack? - included
- cutlery tray? - included
- type of hinges? - using a brand that starts with Eff...cannot rmbr the full name
Master Bedroom
eg. supreme - Supreme 9mm
- frame or frameless - Frameless
Plumbing Works
1 x storage heater
1 x kitchen sink
- includes e storage heater, kitchen sink & bathroom accessories? - yes
- extension of water supply piping for kit sink & washin machine? - yes
- extension of water drainage piping from kit sink & washin machine? - yes
- inlets & outlets pts? - yes
- gas piping? - yes
Miscellaneous
- haulage? - included
- clearing of debris? - included
- once hacking is involved, gota apply permit. If needs P.E. endorsement, how much P.E. fees u gona bear? - included
- instal tap at kit sink? - included
- instal hood & hob - included
Total costs: $25K
- 7% GST?
Finally placed the deposit with my ID yesterday...managed to bargain down to 24k...looking forward to start of reno..
Attention: Icegal
Kitchen
Make sure it is paid as one LUMP SUM. Make sure ur ID don't charge you seperately.
No shower kerb stated? U must have shower kerbs done before you can install the framless tempered glass shower screen. Any Hidden cost?
Plumbing Works
1 x kitchen sink with kitchen tap
U can get it for FOC
Miscellaneous
instal hood & hob
You can get for FOC also
Most Impt thing is read all the tiny clauses before you sign on the dotted line and please make sure no hidden costs.
Edited by pro2
