SmartFool
Reno Quote
Hi All
need some help here
i have been doing alot of research as well as viewing other peoples quotes
below is a quote for my place
i personally think tht the electrical is very ex
pls advise
thanks
:furious:
PART A - GENERAL WORK
1) HACKING AND HAULAGES Price S$
Supply labour and equipment to :~
1.1 Remove existing laminate flooring to Whole house. LS $650.00
1.2 Hack floor tiles to Living & Dining. LS $400.00
1.3 Hack wall & floor tiles to Kitchen. LS $750.00
1.4 Hack floor tiles and skirting to Private Garden's Terrace. LS $200.00
1.5 Hack floor- and wall tiles to Master and Common Bathrooms. 2unit $900.00
1.6 Hack floor tiles and skirting to Roof Garden. LS $400.00
1.7 Hack floor tiles and skirting to Master and Bedroom 2's Balcony. LS $200.00
1.8 Dismantle existing build in wall feature and TV console ****. LS $250.00
1.9 Dismantle existing Kitchen cabinets and Island unit. LS $250.00
1.10 Dismantle existing built-in wall feature at Master Bedroom. LS $180.00
1.11 Dismantle existing built-in walk-in wardrobe at Master Bedroom/2. LS $350.00
1.12 Dismantle existing built-in wardrobe at Bedroom 4. LS $180.00
1.13 Dismantle existing bathtub, toilet bowl, vanity cabinets and shower screen at all Bathrooms. LS $300.00
1.14 Haulages for loading of materials and clearing of debris and hardcore off-site. LS $800.00
2) MASONRY AND TILING WORKS
Living, Dining, Kitchen
2.1 Supply and install 600 x 600mm homogeneous floor tiles to Living, Dining & Dry Kitchen. $2,500.00
2.2 Supply and install 300 x 600mm homogeneous floor tiles to Wet Kitchen. $700.00
2.3 Supply and install ceramic/homogeneous wall tiles to exposed surfaces at Wet Kitchen. $1,200.00
2.4 To plaster cement & sand with skim coat smooth finishing to Dry Kitchen. $900.00
2.5 Supply and construct concrete Kitchen cabinet base with tiles trimming. ('L' shape) $350.00
2.6 Supply and install concrete fridge base with tiles finished. $100.00
2.7 Supply and install concrete washing machine base with tiles finish. $100.00
2.8 Supply and install 300 x 600mm homogenous floor tiles with skirting to Private Garden 's Terrace. $1,000.00
2.9 Supply and apply waterproofing membrane to Kitchen and Terrace. $300.00
3) Bathroom 1 ( 2nd Storey Master Bedroom )
3.1 Supply and install 300 x 300mm homogeneous floor tiles. $450.00
3.2 Supply and install ceramic/homogeneous wall tiles. $1,500.00
3.3 To construct shower kerb with tiles finished . $100.00
4) Bathroom 2 ( 2nd Storey Bedroom 2 )
4.1 To apply bonding agent with skim coat smooth plastering finished to wall. $600.00
5) Bathroom 3 ( 3rd Storey Bedroom 3 )
5.1 Supply and install 300 x 300mm homogeneous floor tiles. LS $400.00
5.2 Supply and install ceramic/homogeneous wall tiles. LS $1,250.00
5.3 To construct shower kerb with tiles finished . LS $100.00
5.4 Supply and apply waterproofing membrane to 2 Bathrooms. $300.00
6) Balcony
6.1 Supply and install 300 x 300mm homogeneous floor tiles c/w skirting to 2 Balcony. $900.00
6.2 Supply and apply waterproofing membrane to 2 Balcony. $160.00
7) Roof Garden
7.1 Supply and install 300 x 300mm homogeneous floor tiles c/w skirting. $1,500.00
7.2 Supply and apply waterproofing membrane to 2 Bathrooms. $350.00
8) FLOOR FINISH & STAIRCASE
8.1 Supply and install Laminate flooring c/w skirting to 4 Bedrooms, Hall and Landing. $3,000.00
8.2 Supply labour and material to sand down and apply black paint to existing wrought-iron railing. $900.00
8.3 Supply and install new timber plank with black stain and varnish finishes over existing steps, to install cement board to paint to finish below timber plank vertical wall. $4,200.00
9) PAINTING LS $3,500.00
9.1 To apply oil-base sealer to false ceiling at Bathrooms, Kitchen and new walls.
9.2 To apply white emulsion paint to all ceiling.
9.3 To apply 'ICI' or 'Nippon' emulsion paint to all internal walls.
10) SHOWER SCREEN
10.1 To construct 'L' shape shower screen, aluminium frame with 4.5mm thk tempered glass and sliding door. ( Bathroom 1 & 3 ) $580.00 2set $1,160.00
11) PLUMBING WORKS. ( conceal )
11.1 Supply and install copper pipes for hot & cold water supply to Kitchen and 2 Bathrooms, cold water supply to Private Garden and Roof Garden. LS $3,200.00
11.2 Supply and install outlet PVC pipe for discharge to Kitchen and 2 Bathrooms, Private Garden and Roof Garden. $450.00
11.3 Supply labour to terminate inlet and outlet piping work at Bedroom 2's Bathroom. $80.00
11.4 Supply Labour to install pedestal bowl ( W.C ) at Bathrooms. 2set $240.00
11.5 Supply Labour to install wash basin and basin mixer. 2set $160.00
11.6 Supply Labour to install shower mixer and shower set. 2set $160.00
11.7 Supply Labour to install Kitchen sink, tap and fittings. 1set $80.00
11.8 Supply and install tap to Private Garden and washing machine at Roof Garden. 2set $40.00
11.9 Supply Labour to install bathroom accessories. 2set $100.00
12) ELECTRICAL WORKS ( conceal )
12.1 Lighting wiring point ( 1 way ) @ 65.00
12.2 13amp power point ( single socket ) @ 90.00
12.3 13amp power point ( double socket ) @ 100.00
12.4 SCV television point. @ 150.00
12.5 Relocation of lighting switch/socket @ 50.00
13) Miscellaneous
13.1 To sand down and varnish existing door panel and door frame. @ 60.00/set 8set $480.00
13.2 Chemical wash to all floor- and wall tiles, and general cleaning to whole house. LS $500.00
PART A - Total : $38,820.00
PART B - CARPENTRY WORKS
1) WET KITCHEN
1.1 Supply labour and materials to fabricate and install wall hung Kitchen cabinet c/w swing door in laminate finishes and ABS trimming. 7ft. $770.00
1.2 Supply labour and materials to fabricate and install 'L' shape bottom cabinet c/w swing door in laminate finishes and ABS trimming. 16ft. $1,760.00
1.3 Supply and install solid surface worktop c/w backsplash and front profile above 'Bottom' cabinet. 16ft. $1,280.00
2) DRY KITCHEN
2.1 Supply labour and materials to fabricate and install full height cabinet c/w swing door in laminate finishes and ABS trimming. ( with opening for fridge ) 8ft. $1,500.00
2.2 Supply labour and materials to fabricate and install top & bottom cabinet c/w swing door in laminate finishes and ABS trimming. 5ft. $1,100.00
2.3 To construct 'Island' unit c/w pull out drawers in laminate finish. 5ft. $650.00
2.4 Supply and install solid surface worktop c/w backsplash and front profile. 10ft. $800.00
3) LIVING
3.1 To construct wall feature in veneer/laminate finishes c/w wiring compartment for wall hung T.V. 8ft. $1,440.00
3.2 To construct wall hung T.V console in veneer/laminate finishes c/w drawer and glass panel. 9ft. $1,170.00
4) MASTER BEDROOM
4.1 To construct wardrobe c/w hanger rod, shelves, drawers and swing door in laminate finish. 10ft. $2,200.00
4.2 To construct wardrobe c/w shelves, drawers and swing door in laminate finish. 5ft. $1,100.00
4.3 To construct tall storage cabinet c/w shelves and swing door in laminate finish. 4ft. $880.00
4.4 To construct wall feature in veneer/laminate finishes, with wiring compartment for wall hung T.V. 6ft. $1,080.00
4.5 To construct wall hung T.V console in veneer/laminate finishes c/w drawer. 5ft. $650.00
4.6 Dressing table with mirror at Changing room. est. $800.00
5) MASTER BATHROOM
5.1 To construct suspended vanity cabinet with drawer and swing door in laminate finish. LS $450.00
5.2 To supply and install 'Black' glass vanity top c/w backsplash. $300.00
5.3 Supply and install mirror above vanity. $280.00
6) BEDROOM 4
6.1 To construct wardrobe c/w hanger rod, shelves, drawers, mirror and swing door in laminate finish. 6ft. $1,320.00
7) Bathroom 3 ( 3rd Storey Bedroom 3 )
7.1 To construct suspended vanity cabinet with drawer and swing door in laminate finish. $400.00
7.2 To supply and install 'Black' glass vanity top c/w backsplash. $280.00
7.3 Supply and install mirror above vanity. $220.00
PART B - Total : $20,430.00
PART A + B - Total : $59,250.00
this is some of the homework i did
can refer to as well if u need some comparisons
http://www.renotalk.com/forum/index.php?showtopic=13850 – sequence for renovation
http://www.renotalk.com/forum/index.php?sh...c=7184&st=0 – best quote
http://www.renotalk.com/forum/index.php?showtopic=13360
http://www.renotalk.com/forum/index.php?showtopic=13700 – kenna chop carrot
http://www.renotalk.com/forum/index.php?showtopic=13827
http://www.renotalk.com/forum/index.php?showtopic=15323 – use as comparison for quote
http://www.renotalk.com/forum/index.php?showtopic=15344– use as comparison for quote
http://www.renotalk.com/forum/index.php?showtopic=15120 – use as comparison for quote
http://www.renotalk.com/forum/index.php?showtopic=14335 – use as comparison for quote
http://www.renotalk.com/forum/index.php?showtopic=14625- – use as comparison for quote
http://www.renotalk.com/forum/index.php?showtopic=15128 – use as comparison for quote
http://www.renotalk.com/forum/index.php?showtopic=14662 – use as comparison for quote
http://www.renotalk.com/forum/index.php?showtopic=14578– use as comparison for quote
http://www.renotalk.com/forum/index.php?showtopic=14631 use as comparison for quote
http://www.renotalk.com/forum/index.php?showtopic=14593
1 toilet approx 3k
http://www.renotalk.com/forum/index.php?showtopic=14978 – Electrician cost
http://www.renotalk.com/forum/index.php?showtopic=14583 – tempered glass backing
http://www.renotalk.com/forum/index.php?sh...=13307&st=0
http://www.renotalk.com/forum/index.php?showtopic=14808 – 25k reno for 2 toilets and mbr
http://www.renotalk.com/forum/index.php?showtopic=14587 – haulage
http://www.renotalk.com/forum/index.php?showtopic=13991 – 24k quote for whole place
http://www.renotalk.com/forum/index.php?showtopic=13473 – for 3 room quote
http://www.renotalk.com/forum/index.php?showtopic=12950 – guide to reno
http://www.renotalk.com/forum/index.php?showtopic=13706 – adjustments in quotations
http://www.renotalk.com/forum/index.php?sh...1925&st=240 – blum, hettich
bro...quote comparison is very difficult because of the difference in the house size and the material involved...even the best quote cannot be use as a comparison because the price is based on last year january i believe..
btw..you took which ID? maybe you would like to ask my ID for quote comparison and see whether you can save any money or not...PM me if you are interested...
Guest Chern38
urs is a landed house...???? otherwise it won't cost ur lots of money .... however price seems very high while me n my dear spent $30k plus for whole ren ...n save us lots of $$$$ ..so my hubby n i can have extra $$$ for our furniture shopping n honeymoon trip !! hehe...
my contractor gave us a better price as compare to other ids & contractors because is recomended from my hubby's relative....compare to others, the contactor shows his responsibility well and handle the task very well even though he delay the handover date to us due to some delay of works...as he said he want to do it well for us...overall still very satifsed with his workmanship n service as well.......
if u are interested, can pm and look for him......
Priscilla, i see that you've done quite a lot of comparison. do keep in mind that different contractors, different workmanship & years of experience... :yamseng:
I know 2 bosses and 1 ID, all from different companies.
Firstly, is Ah Kee who deals with all my bosses' renovations. i have 5 bosses. he's in charge of all of our office building's renovation works, which is 5 storey high and more than 10 years old.
he's not very modern but my boss says he charges reasonably. all my bosses very picky and stingy one. LOL
Secondly is Mr Pang from Squareroom. i'm his brother's friend and i've been to their place, workmanship very smooth and nice. highly suspect only renovated their kitchen cos look very new and comfy.
Thirdly is an ID who works for Prestige Image and Build. has got very experienced contractors.
what i know of is that Ron got a client who signed a contract with him after signing with another. reason being the other company overcharged him for the same renovation works. so they had to show the previous ID Ron's quotation and they'll cancel off the contract. think might forfeit the deposit though...
Second one offered me commission, but i'm not interested. :D
defeat the purpose la. intro you guys cos you all need reasonable pricing but i still wanna earn from you all... so no need to mention my name.
interested just PM me.
