simpleguy80
Need Your Help In Fengshui
Mmmm the inlet pipe is easy but the outlet pipe and the floortrap are not there. They are located at the planned position or at the service balcony. May i know what is the effects for placing cooker hob at the wall sharing with toilet? Which one is more bad, back facing the kitchen entrance or wall sharing with toilet?
maybe this is a good thread
http://www.renotalk.com/forum/index.php?sh...all+with+toilet
and this is foor good stove position,
"as long as not facing toilet/window/entrance should be ok.
by right need to see bazi + whole floorplan to determine best position"
Mmm mine not face toilet is sharing the wall with toilet that mean one side of the wall is the toilet and another side is the kitchen.
stove cant face kitchen entrance...so does it means directly face? if the side of the stove face the entrance izit ok?
It's not good to have stove in front of kitchen door be it direct or side. This is like a mini T-junction, the Sha Qi from the door rushes in and hit the stove.
this is a very difficult case, because the two walls are not parallel, there are two facing directions, where your stove is should depend on your house facing direction.
Mmmm dun understand what you mean by depend on my house facing direction? So how do i determine my facing direction?
Oh then where is the best location for the stove?
Kitchen Feng Shui
1. Kitchen should never be located in the central palace or Heavenly Heart of the property i.e. center of the house.
2. The sink should not be opposite the stove
3. The stove should not be located infront of the kitchen door
4. The stove should not be located below a beam
5. The sink must be a least 2' from the stove
6. The kitchen should be located in a negative sector of the house based on the House Gua. the purpose of locating the kitchen in a negative sector is to suppress the negative Qi in the property
7. Avoid kitchen with #5, #2, #5 and #2, #2 and #3 star
Item 6 is based on Eight Mansions Feng Shui
Item 7 is based on flying Star Feng Shui
Note: It's almost impossible to find a house with perfect FS. Very often one have to compromise but never compromise on the location of the front door.
Edited by Diavonex
It's very difficult to establish the facing of a pie shape building.
If you get the facing wrong, the plotting of the stars will be wrong.
Suggest you get a professional FSM.
The how much does it cost to engage a professional FSM?
Suggest you focus on observing the forms and leave the formula to the consultant.
General form guidelines
1. Main door must not be affected by “poison arrows” e.g. edge of buildings, lamp post, tree, narrow gap
2. Square and rectangle layout are better than odd shape
3. House should not have any missing sectors
4. Building main door must be bright, spacious (bright hall) to collect Qi
5. Unit must not face narrow gap formed by two opposite blocks
6. Unit should be near but not facing the lift
7. Apartment should have windows on all sides if possible; better flow of Qi
8. Main door must not be in-line with back door
9. Main door must not face fire escape or rubbish chute
10. Building must not be on stilts; avoid the 2nd floor if there's no 1st floor
11. Avoid building that has a straight road crashing into it
12. Avoid building that access lift lobby via basement car park
13. Avoid highway cutting into building
14. Avoid building located at the fork of a road
15. Avoid wedge shape and narrow building
16. Avoid building where you have no idea where the main entrance is
17. Elevated main entrance is generally not favourable because the main door is located too high and cannot receive Qi
18. Kitchen should not be in the center of house
19. Sink must not face stove
20. Sink and stove must be at least 1 to 2 feet apart
21. Kitchen door must not open directly towards stove
22. Do not locate stove under beam this cause fluctuation of Qi and the stove will be violently affected.
23. Do not sleep under a beam
24. Position the headboard of bed against a wall
Edited by Diavonex
