gbn2377
3 Rm Renovation
Dear all
I would like to check with u all about this
I would like to do the following for kitchen and one toilet and one bathroom(3I corner resale)
renovate the kitchen,toilet&bathroom
but the kitchen need to plaster back only-no wall tiling
plaster the living room wall
hacking and put homo tiling for living room
rewiring the kitchen and living room
fixing cronies for living room
changing windows and and main door grill
painting whole house
Can do all this within $13k??
... mm the things you do are the expensive ones... plastering/windows/ rewiring... mm
renovate kitchen and toilet means you hacking up all the tiles and re-tile? very difficult to be within $13k ba.
actually the current wall tiles are half the wall and I don,t have the plan to do tile back kitchen wall.............. :unsure:
wah.... very tough. Baring a miracle
to cut costs
1. Overlay floor and wall(toilet) tiles
2. kitchen wall - cement over and paint.
3. Might have to give up plastering + cornice (if thats what you are referring to)
4. Paint yourself
Bearing in mind the sure to incur hidden/additional costs, when asking for quote state $11,000 to absorb all those surprises...
how about your water pipes ?
rough quote for my in laws 4 room :
kitchen bottom cabinets
kitchen wall floor tiles
2x toilet wall floor tiles
change all cast iron sanitary pipes in both toilets and kitchen to PVC
works include dismantling and hacking of existing tiles and cabinets
the above already amount to $10k+ liao
Edited by ivy
Dear all
??? What you intent to do??? Kitchen cabinet, wardrobe, vanity cabinet,??? Hacking existing wall tiles, cement and paint ~ $1K - $1.5K
Should be ard $500 or less than that.
Hacking around $1K + disposal. Tiles depend on the range you select, ard $2.30 ~ $10 psf.
Mostly it was calculate by per power point.
Depending on design, ard $3 pfr.
Aluminium $4 psf wronght iron grill $15 psf (not powder coated)
Should be ard $1K
I just want kitchen cabinet only.Cos i don't intend to renovate any other room
may be I can do overlaying of laminate in living room to cut cost.right ?? save at least few hundreds???
but overlaying kitchen and toilet very dif I feel cos its very old( those original cond with 1/2 of wall white tiles)(25 year old flat)
Came up with this budget cos see many advt I offer kitchen and 2 toilets renovation for resale flats offer ~$9k :unsure:
4. Paint yourself
never done before :)
Edited by gbn2377
Kitchen cabinet is ard $90 ~ $140 pfr. Kitchen top what u intend to use?
Yes u can overlay, save quite a lot. U can also try using vinyl flooring.
Don't recommend to overlay unless you want to consider what I had done for my kitchen and toilets floor.
It normal but may have hidden cost.
4. Paint yourself
Then don't do it.
$13K is possilbe in this case if not doing wardrobe, vanity top and cabinet.
Edited by jaskel
What I am planing is to make a better cabinet with solid top but size keep to 18sqf to save some.
what have you done??
Anybody can let me know how much app: cost to do rewiring of 3I living and kitchen only????
Edited by gbn2377
rewire for 3 room prob 1k thereabouts...the expensive part i thk is the light points...if u wan to fix downlights etc...that wil take up alot of pts and each pt cost min $30...
overlay laminate is a good budget alternative....now they come w 10yr -15 yr warranty shd b quite ok..
cabinet is ard 90 -140...solid top prices start fr $70...
Sorry , is it 18ft u r saying (Bottom 18ft, top 18ft or bottom only)? Solid top recommend u take good brand. Corian top ard $110-$140.
I do sediment flooring over my existing tiles, check my T-blog for photos.
Set aside $1K for rewiring, it should be more than enough.
no I was planning to have 9 ft each bottom and top....
And to make a 9 ft solid top....
just worried does it pop up after some times
no plan to make any extra light points.But planing change light fittings only
Edited by gbn2377
