Many Uses Of Rubbing Alcohol
Thought you guys might find this useful. I also use it to fix my broken eyeshadow and pressed powder. :P
Rubbing alcohol is 70 percent isopropyl alcohol and 30 percent water, and is safe for contact with the skin. It has a number of general medicinal and household uses. This list of ideas makes having a bottle of rubbing alcohol in the house a good idea
Remove hair spray and toothpaste from mirrors
When you are spritzing your head with hair spray, some of it inevitably winds up on the mirror, same goes for the toothpaste !
A quick wipe with rubbing alcohol will whisk away that sticky residue and leave your mirror sparkling clean.
Clean venetian blinds
Rubbing alcohol does a terrific job of cleaning the slats of venetian blinds. To make quick work of the job, wrap a flat tool -- a spatula or maybe a 6-inch (15-centimeter) drywall knife -- in cloth and secure with a rubber band. Dip in alcohol and go to work.
Keep windows sparkling and frost-free
Do your windows frost up due to the aircon? Wash them with a solution of 1/2 cup rubbing alcohol to 1 quart (1 liter) water to prevent the frost. Polish the windows with newspaper after you wash them to make them shine.
Prevent ring around the collar
To prevent your neck from staining your shirt collar, wipe your neck with rubbing alcohol each morning before you dress. Feels good too.
Clean your phone , laptop and keyboard
Is your phone getting a bit grubby? Wipe it down with rubbing alcohol. It'll remove the grime and disinfect at the same time.
One of the advantages of rubbing alcohol is that it evaporates so quickly once you apply it to something
Remove ink stains
Did you get ink on your favorite shirt or dress? Try soaking the spot in rubbing alcohol for a few minutes before putting the garment in the wash.
Erase permanent markers
Did Junior decide to decorate your countertop with a permanent marker? Don't worry, most countertops are made of a nonpermeable material such as plastic laminate or marble. Rubbing alcohol will dissolve the marker back to a liquid state so you can wipe it right off.
Remove dog ticks
Ticks hate the taste of rubbing alcohol as much as they love the taste of your dog. Before you pull a tick off Fido, dab the critter with rubbing alcohol to make it loosen its grip. Then grab the tick as close to the dog's skin as you can and pull it straight out. Dab again with alcohol to disinfect the wound. This works on people too.
Get rid of fruit flies
The next time you see fruit flies hovering in the kitchen, get out a fine-misting spray bottle and fill it with rubbing alcohol. Spraying the little flies knocks them out and makes them fall to the floor, where you can sweep them up. The alcohol is less effective than insecticide, but it's a lot safer than spraying poison around your kitchen.
Make a shapeable ice pack
The problem with ice packs is they won't conform to the shape of the injured body part. Make a slushy, conformable pack by mixing 1 part rubbing alcohol with 3 parts water in a self-closing plastic bag. The next time that sore knee acts up, wrap the bag of slush in a cloth and apply it to the area. Ahhh!
Stretch tight-fitting new shoes
This doesn't always work, but it sure is worth a try: If your new leather shoes are pinching your feet, try swabbing the tight spot with a cotton ball soaked in rubbing alcohol. Walk around in the shoes for a few minutes to see if they stretch enough to be comfortable. If not, the next step is to take them back to the shoe store.
Clean bathroom fixtures
Just reach into the medicine cabinet the next time you need to clean chrome bathroom fixtures. Pour some rubbing alcohol straight from the bottle onto a soft, absorbent cloth and the fixtures. No need to rinse -- the alcohol just evaporates. It does a great job of making chrome sparkle, plus it will kill any germs in its path.
Minimize reactions to earrings
If you take a bit of rubbing alcohol and apply it to the post of your earrings, then it will help the earring insert far more smoothly.
Also, take some rubbing alcohol on a tissue and rub it around your ear.
Remove Stickiness
Have you ever bought a picture frame only to find that the price sticker won't come off? I mean you tried everything and the residue is still sitting right dab smack on the glass of your new frame. Soak a cotton ball in some plain rubbing alcohol and place the soaked cotton ball on the sticker. The trick is to let it sit for a minute or so until the alcohol has penetrated the sticker and sticky residue. Then rub the cotton ball over the sticker and watch it all just wipe away!
Clean a Skipping CD or DVD
When finger prints grace the backside of your DVD's and CD's they are likely to skip and not perform well. A neat, very inexpensive trick is to spritz the CD or DVD with some alcohol and wipe with a clean, lint free cloth. The finger prints will literally dissolve when the alcohol hits it
Remove wax from carpet
If you had a beeswax candle that spilled on your carpet, you can use rubbing alcohol to help remove the wax. Start by pulling the largest clumps of beeswax from the carpet. Once removed, you can dab the carpet with a paper towel soaked with rubbing alcohol to remove the remnants.
Helps with mosquito bites
Rubbing alcohol can actually help with mosquito bites a lot better than store-bought remedies. Just rub it on the bites and it will dry them out bringing quick relief.
  • 7 months later...
