wonderlee
Need Advice On Centralise Water Heater
My new EM has this centralise water heater. Heard from my friends that we have to one the electric for roughly 10 mins before the water gets heat up. Any other things that is more cons than pros?
My new EM has this centralise water heater. Heard from my friends that we have to on the electric for roughly 10 mins before the water gets heat up. Any other things that is more cons than pros?
About there...it also depends on the gallon of your tank.
Cons - you need to run copper pipes so it cost more for your reno....
Centralise water heater maybe a good choice, unless you want all ur house to have warm water. Eg. kitchen tap, washing machine and both toilets basin taps.
But you need to know how much usage on your family and you then you can decide the size of the tank. If usage is a lot would be good to on whole day then switch off in the night time.
Agree on what dankoo type. More copper or stainless steel pipes will be required.
