Who Should Be Boxing Up Aircon Trunking?
It should be aircon guy, right ?
How come my aircon guy says he does not do that ? :unsure:
Contractor.
He'll do box up and touch up.
air con guy only do the trunking.
boxing up is done either by plaster guy or carpenter. depending on what u intend to use to box up
after boxing up, would there be problems accessing the trunking IF there are problems with installation?
sorry but I'm just a novice..thanks
what material can be used for boxing up?
if pipes do not leak I guess you dont ever need to touch the boxed up parts.
If suay, then have to tear away box up
If condensation take place then it will damage the box-up. Do make sure the air con man do a good insulation.
thanks simplez and strawberry8
I will take note.
seriously, I never seen people boxing up aircon trunking. It is expensive n not so effective in my opinion because you can just paint over the trunking. When there is leakage, need to remove box up. In addition, also troublesome if u decided to replace trunking.
boxing up is to beautify the place. but also causes problems in future if pipes are leaking or needs to be replaced.
I have a friend who find the air con trunking running from her bedroom to the toilet very eyesore and she get it box-up.
I guess it is up to individual preferences.
  • 4 weeks later...
Hi Simplez
Has good insulation anything to do with Class0 and Class 1? What do they refer to? I am so lost in these aircon tech terms. Pls help!
Mookie
Hi Simplez
Mookie
the class rating of insulation actually refers to the fire retardation. class 0 insulation is actually more resistant to fire as compared to class 1. no difference in insulation properties. at least that is what i was told
Thanks :D
Without a doubt, aircon guy only do trunking/piping. The boxing is done by contractor.
Edited by pocus
