yeo99
My Little Home At Tamines
At closer look, workmanship for sliding door doesn't look good.
A responsible cabinet contractor to redo the door thickness. But can't he also do the same for the al door which is giving you problem?
Overall, nice and clean feel.
The sliding door problem is a very bad experience for me and my wife, the price is much higher than the sliding glass door and yet the quality is a very bad (hollow door, poor finishing, poor installations, etc).
It is up to the main contractor and the sub-contractors, I have push him for the rectification of Al door before. After some uses, it goes back to the original position; You are right, the best is to change the one piece Al door to ensure smooth closing.
Overall Al works and doors works from B*** I***** have bad workmanship.
Edited by yeo99
Picture on area where the cabinet and kitchen sliding door:
Part 2 Planning Stage:
Items to be done:
1. Two Toilets (common and master bedroom)
2. Bedroom Doors and Door frames
3. Living room light box.
4. Kitchen lightings
Will be posting the details soon.
I will be starting phase II soon under a different contractor ......
Will keep you posted.... Stay tune...
Master Toilet Basin and Bowl:
I have purchased the following things:
1. Toilet bowl:
Crizto : CWC-2350-WT
2. Wash Basin
Crizto : CCB-8085-WT
3. Basin Faucet
Showy : 3024
4. Bidet Sprayer
Bossini patty
Edited by yeo99
Common Toilet Basin and Bowl:
1. Toilet bowl:
Crizto : CWC-2815-WT
2. Wash Basin
Velin : 605-WT
3. Basin Faucet
Arino : 7016
Together with the wall plug , basin trap and etc, I spend $650 for both toilets. They are from Elite Sanitary Trading, if you are going there, look from Yi Ting, she is a very nice salesgirl. Said you are recommended by Mr Yeo from Tampines, maybe you will get some more discounts :D
269 Changi Road Singapore 419752
Tel : 6842 3898 Fax : 6742 1372
Edited by yeo99
Last weekend, too busy re-organising the store room. I brought the Gorm system from Ikea. I added the height extension post so as to reach a height of 233cm.
Not bad, can put alot of things inside the store room now.
Looks good. How much is the gorm system from Ikea? You assemble of they do for you?
Tks.
Tks.
It is cheaper to buy a set (GORM - shelving unit). Then added the extension to it.
See below:
Gorm set
It is asembled by my wife and me, not that difficult but need two people.
Common Toilet Tap and Accessories:
1. Two ways Taps:
Fidelis : FT-106-3 - $32
2. On/off Tap for Instead water heater
Showy: 2657N Cross quarter turn C/C stop cock - $14
3. Water heater
Alpha : WH 8668P - come with 120W AC Pump to boost up for 4 x water pressure (if your water pessure is sometimes too low during peak hours) - installed two years ago
4. Toilet roll holder
Ikea - BAREN toilet roll holder chrome-plated - $19
Edited by yeo99
Master Toilet Tap and Accessories:
1. Two ways Taps:
3. On/off Tap for bidet hand sprayer
Showy: 6062 quarter turn - $12
4. Water heater
707 : Alpine - installed two years ago
Edited by yeo99
Mitsubishi Electric System 3 inverter Aircon:
The System 3 consists of MMXY-3A28VA (QTY=1) , MSY-GA10VA (QTY:2 ) and MSY-GA13VA (QTY:1 )
The MSY-GA10VA fancoils are for the two bedroom and MSY-GA13VA fancoil is for the living room. The MSY-GA13VA is 1.5hp as compared with MSY-GA10VA is 1hp.
I brought the system 3 two years ago with the price less than $3000 (should be) with installation and it also comes with Stainless Steel Bracket and Power Point. It is from Tai Wah Aircon (authorised dealer for Mitsubishi Electric Aircon). Call them for a quotation, and their price is very resonable and their service is friendly.
Tai Wah Refrigeration & Air-Con Services
No. 12/14 Lorong 23 Geylang Singapore 388357
Tel:(65) 6745 8198
Edited by yeo99
I love your mosiacs...if i could redo my kitchen again..i would do that.
anyw if u wanna, changing your lights to those warm white will create those ID picture effects :)
Re-runing of Aircon trunking:
Unfortunately, during the first installation, I forgot to consider the trunking routing, as a result it is very ugly. I need to re-run the aircon trunking, still talking to and getting some qoutations from the aircon contractors before making a decision.
Old layout:
New layout (wanted):
Lessons learnt: Painful and costly
Edited by yeo99
Thanks eiffel76, the phase 2 renovation has already started on 18 Oct. The place now is very messy and stressful to live as I am staying in, same as fuji_apple74 T-blog says initally very excited after a while , it becomes very tired. I totally can understand fuji_apple74, I also wish it could finish ASAP ...
Old layout:
Some quotations are cheap because they reuse the existing gas pipe and water pipe. I am not sure in long run, will it create a problem? ..
Lesson learnt : Ask whether they reuse the existing gas pipe and water pipe. What is the material used?
Edited by yeo99
