Joel Ng
Good Painter And Plumber To Recommend
For goodness sake, if any of u have the contacts, just post here pls. Dun need to pm here n there lor..
I had recommend a good painter to this forum before and i believe some of you had already engage him before,
trust me, i am not a relative or friend but just a very satisfied home owner who had engage him 2nd time for my parent
flat last week. (note i am not getting commission either)
The reason i am highly recommend him cos i am also like anyone of you who are worry calling those painter in the paper who might end up doing a bad job or hidden cost.
this guy price are reasonable and he is responsible enough in his job to come back when i am not satisfied with any part of the area he had paint.
Beside this , he had also recommend me a plumber who charge me only $15/- for minor plumping job (without parts) i think most ppl will charge at least $30/- for minor job cos of transportation. (this is the first time i am using him)
For those who keen might want to PM me for both the painter and plumber tel.
will your painter paint 2 to 4 walls? painted with oil base sealer first and sail water nippon odorless easywash paint.
will he accept this job?
Just got my house painted by the contractor recommended by joemit (person whom started this thread). The contractor's name is Frank. I am putting up a recommendation again for him based on my good experience in engaging his painting services very recently.
His quote was the most reasonable among 3 quotes I got from different contractors. He is very sincere and knowledgeable in his field and was very kind to offer suggestions on color scheme and other minor repair works around the house. He even helped to fix the room door that was starting to fall apart before painting it.
You can PM me for his contact or check out joemit7805's profile. His number is there under the comments.
Pls PM the contact.
Much appreciated.
Regards.
Hi Joemit
Can you pls pm me the painter contact or you can also email it to me at jessey.leisure@gmail.com
Edited by jtee
