vratenza
B&w Mt30 + Onkyo Tx-nr708
I need some advice on installation of the Onkyo sound system . Should Onkyo wirings be installed first before fixing the false ceiling, lightings and LCD TV?
Deeply appreciated!
Whatever wiring that you anticipate needs to run through your false ceiling, as far as possible, install before your false ceiling is completed. If not. then you should get strings put in place, so that when you finally want to install the wires, can tie to one end of the string and pull through.
