Help With Water Stains On Lower Part Of Walls
I just moved in a terrace house and water stains have surfaced on the bottom parts of some of my walls on the ground floor, especially in the living room
The paints will come out a little looking a bit yellow-ish with lots of small “bubbles”
The painter has come to re-coat some water-proofing stuff and re-paint a few rounds but some of the stains still surface after a week.
The contractor says it’s due to humidity?
Anyone has experience dealing with this?
Thanks in advance!
Thanks in advance!
Similar to the problem I had encountered since I moved to a 20+ years condo about 3 years ago. When I decided to change my conceal pipe due to hacking of toilet tiles, we realised that there is water leakage from the existing pipe. How old is your terrace house?
20+ years
funny thing is, one of the walls is newly built, so unless the new pipes in there leak too :/
  • 3 weeks later...
One possibility could be seepage of soil moisture through your walls. A foundation is suppose to have a thin layer of non water permeable sheet (e.g. aluminium sheet) to stop water seeping up (capilary effect).
I don't know what is the mitigation. Perhaps doing a google on this may give you some idea.
probably due to water proofing not done over the entire wall area..most contractors will tend to save on water-proofing and do only 1 feet(i think)..but have to cover the entire wet area..probably the whole house to be safe
