Hi guys..
I am a newbie here. Need some advice from the more experienced friends here.
Below is the quotation for my 4rm flat reno. Am doing quite a few things as its an old flat.
But am still wondering whether the prices are a bit too much..
Please advice. And thanks for your time.
S/N DESCRIPTION AMOUNT($)
Kitchen & 2 Toilets:-
1 Supply hack and lay kitchen floor tiles c/w water proofing. $ 1,300.00
2 Supply and lay kitchen wall tiles up to ceiling height. ( expose area only ) $ 3,000.00
3 Supply and construct L-shape cabinet, fridge and washing machine base. $ 350.00
4 Supply and install L-shape top/bottom kitchen cabinet of 22ft. $ 3,850.00
5 Supply and install L-shape solid surface kitchen work-top of 22ft. $ 1,650.00
6 Supply and over-lay bath 2 floor tiles. $ 500.00
7 Supply and over-lay bath 2 wall tiles up to ceiling height. $ 1,300.00
8 Supply and construct hollow block lintol for bath 2 c/w tiles finishing $ 200.00
9 Supply and re-located new entrance for bath 1. $ 200.00
10 Supply and seal-up existing door entrance using 63mm hollow block at bath 1.$ 250.00
11 Supply hack and lay bath 1 floor tiles c/w water proofing. $ 800.00
12 Supply and over-lay bath 1 wall tiles up to ceiling height. $ 1,300.00
13 Supply and install tempered glass shower screen at bath 1. $ 338.00
14 Supply and install aluminium bi-fold door at bath 1 and bath 2. $ 360.00
15 Supply and re-run whole house stainless steel pipe. $ 550.00
16 Supply and re-run sink, wash basin and washing machine inlet/outlet pipe. $ 180.00
17 Provide labour to install toilet bowl, wash basin heater and toilet accessories. $ 350.00
18 Supply and install stainless steel bin chute. $ 168.00
Miscellaneous Works:-
1 Supply hack and lay 600mm x 600mm homogeneous fllor tiles c/w skirting ****, 3 bedroom and store room. $ 6,200.00
2 Supply and construct L-shape wall using 63mm hollow block at prayer room of 8ft. $ 750.00
3 Provide labour to make good with cement plaster at L-shape wall. $ 400.00
4 Supply and lay 1 side wall tiles for prayer room. $ 700.00
5 Supply and construct support for prayer altar. $ 400.00
6 Supply and box-up 3 nos door top. $ 120.00
7 Supply and construct false ceiling **** room. $ 360.00
8 Supply and construct 2 sets L-box **** and dining room $ 910.00
9 Supply and plaster whole house wall and ceiling. $ 1,500.00
10 Supply and paint whole hosuse wall/ceiling, bedroom doors/frames and all expose pipe. $ 1,050.00
11 Supply and do chemical wshing after renovation works. $ 250.00
Electrical Works:-
1 Install light 20 x $ 8.00 $ 160.00
2 Lighting point 20 x $ 28.00 $ 560.00
3 13A double point 12 x $ 55.00 $ 660.00
4 15A heater point 2 x $ 80.00 $ 160.00
5 15A air-con point 1 x $ 80.00 $ 80.00
6 Tel point 2 x $ 60.00 $ 120.00
7 SCV point 2 x $ 80.00 $ 160.00
8 Earth point 1 x $ 80.00 $ 80.00
9 DB box 1 x $ 350.00 $ 350.00
