Quotation For 4 Room Premium Bto Flat
Hello Everyone,
I have the following quotation from an ID for my 4 Room Premium BTO flat. Please advise if you detect any irregularities. Doors, tiles have all been included in our flat by HDB. May I also ask, is it normal that ID give quotations without going on site to do measurements?
Thank you!
MISCELLANEOUS WORKS
To Supply Paint of wall & ceiling for whole house include all expose piping (matex paint) $850
To supply & paint existing door frame $100
To supply labour for general cleaning whole house include acid cleaning for floor, wall & window $180
To supply & protect existing flooring **** with corrugated paper $200
PLUMBING WORKS
To supply labour to joint in/out let pipe for kitchen sink $150
To supply & extended stainless steel pipe at kitchen sink $180
To supply labour to install toilet accessories at master toilet $35
To supply labour to install toilet accessories at common toilet $35
To supply labour to install heater $100
To supply labour to install 01 no standard wash basin at master toilet c/w lever tap $70
MASONRY WORKS
To supply & construct 50mm fridge base with tile finish $120
To supply & construct 50mm washing machine base with tile finish $120
To supply & construct 50mm cabinet base with tile skirting $280
To supply & construct 50mm shower kerb at master toilet with tile skirting $80
CARPENTRY WORKS AT L*I*V*I*N*G*R*O*O*M
To supply & fabricate 6ft designed feature wall **** c/w laminate finish $1020
To supply & fabricate 6ft designed TV console with laminate finish $660
CARPENTRY WORKS AT DINING
To supply & install full height mirror at dining area (51sqft) $816
CARPENTRY WORKS AT FOYER
To supply & fabricate 9ft designed feature wall to cover house hold shelter
c/w tic tar door & laminate finish $1620
CARPENTRY WORKS AT MASTER BEDROOM
To supply & fabricate 6ft designed full high wardrobe c/w glass sliding $1440
To supply & install pull out mirror at wardrobe $180
door aluminium frame & laminate finish $1200
CARPENTRY WORKS AT KITCHEN
To supply & fabricate 24ft solid plywood kitchen cabinet c/w laminate finish, $2280
2 glass door, 4 drawer, 1 cutlery tray & 1 stainless steel dish tray
To supply & install 15ft solid surface work top with 3 inch profile $975
CEILING WORKS
To supply & install L-box cornice AT L*I*V*I*N*G*R*O*O*M $450
To supply & install false ceiling at dining with plaster board $450
To supply & install false ceiling at passage way with plaster board $250
To supply & install false ceiling at foyer with plaster board $180
GLASS WORKS
To supply & install 10mm tick wall to wall tampered glass shower screen $310
master toilet c/w swing door
ALUMINIUM / WROUGHT WORKS
To supply & install 45sqf sliding window with wpc finish $630
To supply & install 120sqf aluminium grills with n/a finish $636
CARPENTRY WORKS AT MASTER TOILET
To supply & fabricate 2.5ft suspended vanity cabinet c/w glass door
aluminium frame & laminate finish $325
To supply & install 2.5ft solid surface top c/w 2 inch profile $162.50
To supply & install 1 pc full mirror $180
ELECTRICAL WORKS
To supply & run 14nos lighting point **** & dining room $392
To supply & run 01nos cooker hood point $100
To supply labour to install 22nos owner light $220
Grand Total $16976.50
Edited by abupapa
Hello Everyone,
Thank you!
MISCELLANEOUS WORKS
PLUMBING WORKS
MASONRY WORKS
To supply & fabricate 24ft solid plywood kitchen cabinet c/w laminate finish, $2280 my quote is $24002 glass door, 4 drawer, 1 cutlery tray & 1 stainless steel dish tray
To supply & install 15ft solid surface work top with 3 inch profile $975 my quote is $1050
CEILING WORKS
GLASS WORKS
ELECTRICAL WORKS
The rest are quite comparable to mine.
Surprise that Haulage and clearing of debris was not included? They give it to you for FREE?
Thanks for pointing out to me! I did not noticed that.
How much was your quotation?
Don't mind me asking which ID did u get this quotation from?
The prices looks not bad.
Edited by pheeda
Hi abupapa, please pm me you ID your quotation looks good and within the budget... please pm me thanks in advance... i hope u dont mind sharing...
  • 1 month later...
  • 4 weeks later...
HI,
Can PM me your contractor contact? Thanks in advance.
this price is very very reasonable but i doubt ID work is included
the design should be typical normal Singapore HDB style? good if they have photos of recent completed works to show
The price very cheap. every section is cheaper than the market rate.
nimm12,
spot on. it is indeed a contractor. but they like to call themselves ID.
it is indeed your typical singapore design.
IMHO, I think the chosen furnishings play a huge role too.
I have seen your T Blog and your place looks great! :)
hi all,
this quotation is from Defong Interior. The ID in charge is William.
FYI, I did not engage him in the end but my classmate did.
According to my classmate, William is a very patient and nice guy.
Hope this helps to those who have PM me or asked me for quotation. :)
  • 1 month later...
Hello, can PM your ID num?
Hello Everyone,
Thank you!
<b>MISCELLANEOUS WORKS</b>
To Supply Paint of wall & ceiling for whole house include all expose piping (matex paint) <b>$850</b>
To supply & paint existing door frame <b>$100</b>
To supply labour for general cleaning whole house include acid cleaning for floor, wall & window <b>$180</b>
To supply & protect existing flooring **** with corrugated paper <b>$200</b>
<b>PLUMBING WORKS</b>
To supply labour to joint in/out let pipe for kitchen sink <b>$150</b>
To supply & extended stainless steel pipe at kitchen sink <b>$180</b>
To supply labour to install toilet accessories at master toilet <b>$35</b>
To supply labour to install toilet accessories at common toilet <b>$35</b>
To supply labour to install heater <b>$100</b>
To supply labour to install 01 no standard wash basin at master toilet c/w lever tap <b>$70</b>
<b>MASONRY WORKS</b>
To supply & construct 50mm fridge base with tile finish <b>$120</b>
To supply & construct 50mm washing machine base with tile finish <b>$120</b>
To supply & construct 50mm cabinet base with tile skirting <b>$280</b>
To supply & construct 50mm shower kerb at master toilet with tile skirting <b>$80</b>
<b>CARPENTRY WORKS AT L*I*V*I*N*G*R*O*O*M</b>
To supply & fabricate 6ft designed feature wall **** c/w laminate finish <b>$1020</b>
To supply & fabricate 6ft designed TV console with laminate finish <b>$660</b>
<b>CARPENTRY WORKS AT DINING</b>
To supply & install full height mirror at dining area (51sqft) <b>$816</b>
<b>CARPENTRY WORKS AT FOYER</b>
c/w tic tar door & laminate finish <b>$1620</b>
<b>CARPENTRY WORKS AT MASTER BEDROOM</b>
To supply & fabricate 6ft designed full high wardrobe c/w glass sliding <b>$1440</b>
To supply & install pull out mirror at wardrobe <b>$180 </b>
door aluminium frame & laminate finish <b>$1200</b>
<b>CARPENTRY WORKS AT KITCHEN</b>
To supply & fabricate 24ft solid plywood kitchen cabinet c/w laminate finish, <b> $2280</b>
To supply & install 15ft solid surface work top with 3 inch profile <b>$975</b>
<b>CEILING WORKS</b>
To supply & install L-box cornice AT L*I*V*I*N*G*R*O*O*M <b>$450</b>
To supply & install false ceiling at dining with plaster board <b>$450</b>
To supply & install false ceiling at passage way with plaster board <b>$250</b>
To supply & install false ceiling at foyer with plaster board <b>$180</b>
<b>GLASS WORKS</b>
To supply & install 10mm tick wall to wall tampered glass shower screen <b>$310</b>
<b>ALUMINIUM / WROUGHT WORKS</b>
To supply & install 45sqf sliding window with wpc finish <b>$630</b>
To supply & install 120sqf aluminium grills with n/a finish <b>$636</b>
<b>CARPENTRY WORKS AT MASTER TOILET</b>
aluminium frame & laminate finish <b>$325</b>
To supply & install 2.5ft solid surface top c/w 2 inch profile <b>$162.50</b>
To supply & install 1 pc full mirror <b>$180</b>
<b>ELECTRICAL WORKS</b>
To supply & run 14nos lighting point **** & dining room <b>$392</b>
To supply & run 01nos cooker hood point <b>$100</b>
To supply labour to install 22nos owner light <b>$220</b>
Grand Total <b>$16976.50</b>
