luckycoin
To Build Solid Wall Or Partition
Hello Fellow Forumers,
We are deciding whether to go for partition or solid wall. Measurement is about 7 by 9 ft.
Anyone out there who had done partition or solid wall before, can you guys please give us an idea of how much its gonna cost?
Thanks!!
I just had 2 walls built back between my MBR & common room. Completed only a couple of days ago by a very good contractor. Still do not have the time to upload photographs on RT.
As I am staying in a prefabricated HDB flat, only hollow blocks could be used instead of bricks.
Partition boards are a cheaper option but the acoustic properties are poor. Meaning that if all sorts of noises could be heard on either side of the board. As such there is no privacy.
The pricing depends on the dimensions of the wall that you would like to have. There isn't such a thing as plucking a figure mid-air.
Have u a contractor following up with you already? If u haven't I could recommend you mine because he specialises in cement-related works.
U could PM me if u r interested.
