Most Powerful Air Con For Home
ignore the electric bill. If look for most powerful aircon for Living and dinning, which brand and model is recommend?( biggest HP/watt)
Too bad our house not using 440v bocs my office(440v) 1 unit can cool 3x my living room easily.
Edited by tailgatepro
it might be the toshiba one with 32 BTU
I am going to make tons of assumptions here...
but I am guessing u will need a ceiling cassette to get the max airflow rate. this will allow u to spread the cold air as much as possible, for an immediate cooling effect. If u got double vol ceiling then cassette not advisable.
U will also need an inverter model, which can give a higher BTU/watt ratio.
Anyway.. this may be wad u are looking for. Whether you have space for such a big outdoor condenser or whether there is current limitation, are other issues to consider.
http://www.coolserve.com.sg/htmdocs/products/products_details.asp?id=3090
cool, that was a good website.
too bad, yr recommended model cannot suit HDB.
singapore is getting hotter, my fan is blowing hot wind
i found this http://www.coolserve.com.sg/htmdocs/products/products_details.asp?id=998
look like can install on HDB, but it wouldn't. is it too much load?
That website got a line saying whether can install in HDB.
This model also cannot.
HDB got some blocks with current limitation, some dun have.
Need to check out whether your block got current limitation or not.
But u get this type of 1 to 1.. means bedrooms dun have aircon?
Normally HDB flats get multi-split, and for max power, usually is R410 gas and inverter.
i have aircon for 3 bedroom, but my living room like oven. open windows, next block was so close to each other and block the wind.
