coolwind
Need Advice And Help Regarding New Reno
Bought our first unit. Have to do reno now.
Here is the floor plan and the alterations we want to make:
We have a budget of about 60k-70k (including fittings etc). Following is the list of items. Can it be done?
Aircon with new trunking 1 system 3 and 1 system 2
Plumbing As required
Wiring As required
Install water heater
Replace rubbish chute cover
Master:
Hack wardrobe
Create new wardrobe
Hack Vanity
Varnish Floor
Electrical Points New and re-position
Guest 1:
Hack Wardrobe
Varnish Floor
Guest 2:
Hack Wardrobe
Hack L Wall as shown in floor plan
Replace wall with glass
Change swing door to sliding door. Add 1 more glass door adjacent to living
Create bookcase behind column
Master Bath
Hack and replace floor and wall tiles
Hack long bath
Install fittings (concealed shower, double sink and WC)
Create new glass shower with screen
Cabinets under long mirror
Guest bath
Hack and repalce floor and wall tiles
Install fittings (concealed shower and WC)
Living Room
Overlay existing floor with high grade laminate
Hack existing false ceiling
Create new flase ceiling for down lights
Hack existing wooden platform
Kitchen Redo got 10k quote
i think it can be very nice and sophisticated renovation coolwind...have you engaged any ID yet? any renovation idea (theme and preference)?
Thanks for your replies indira and harleybrian83. We pretty much know what alterations, schemes we want for the house, hence not engaging any ID. But we r looking for a contractor\project manager, but no luck yet with any quotes etc.
Another thing i wanted to check is how do i determine if i need false cieling? Is it purely for show? Can i put downlights without false cieling?
thanks nimm12.
its a pte condo.
the height is 3.2m for now.
we finally decided to not have false ceiling. we'll probably invest in a good light piece!
thanks.
its quite hard to look for gd contractor as most of them only do what they are told and seldom advising you on the disadvantages that ur design might bring. With a little bit of $, i felt that getting a ID would be more adviseable as you can chase after then in future if there is any problem. (heard there is a ID which give "life time warranty" to their projects) *just my 2cents of advise*
its good to invest in a gd lighting as it will be part of the attraction when people come to your place. Most of these lighting are usually warm lighting (yellow). maybe you can choose to do a L box to install cove lighting and downlights to use them during normal day.
