ironstarz
How To Remove Stan From Laminated Surface
Recently just renovated my place, and saw some paint mark on the door, so i took thinner and wiped the paint off, the next thing i knew was that there was some kind of smudge stain left behind , not sure is it because of the thinner or what. Can anyone advise what should i use to clean these stain off ? Tried using vinegar already but does not work. :bangwall:
Apply the right solvent before knowing what kind of paint.
Hydrocarbon Solvent
Aliphatics
Hexane
Alipax 1425 (Special Boiling Point)
Alipax 3040 (Low Aromatic White Spirit)
Alipax D40, D60, D80, D100 series
Aromatics
Toluene (C7)
Xylene (C8)
Aromax 100 (C9)
Aromax 150 (C10)
Ethylene Oxide and Derivatives
Glycols
Mono Ethylene Glycol
Diethylene Glycol
Triethylene Glycol
Glycol Ethers
Ethylene Glycol Monobutyl Ether (BGE/BCS)
Ethylene Glycol Monoethyl Ether (EGE/CS)
Butyl Diglycol Ether
Glycol Ether Esters
Ethylene Glycol Monethyl Ether Acetate (EGAC/CA)
Oxygenated Solvents
Alcohols
Ethyl Alcohol (Ethanol)
Methyl Alcohol (Methanol)
n-Butyl Alcohol (Butanol)
n-Propyl Alcohol
Isobutyl Alcohol
Isopropyl Alcohol
Esters
Ethyl Acetate
n-Butyl Acetate
n-Propyl Acetate
Isopropyl Acetate
Ketones
Acetone (DMK)
Diacetone Alcohol (DAA)
Isophorone
Cyclohexanone (CYC)
Methyl Ethyl Ketone (MEK)
Methyl Isobutyl Ketone (MIBK)
Edited by bepgof
omg, obviously, TS, u make a big mistake to remove paint from doors surface using thinner, since thinner are suppose to be used on marbles, tiles, glass and metalic surfaces which do not have any effect on it. thinner do dissoves plastic and thus it will leave a bad marking. thinner is a very strong organic solvent and should be avaoided if possible. try to use water, then alcohol, den lighter fluid, den nail polisher and finally thinner in that order as the dissolving power get stronger. of course, if the damage is done den, too bad....
u can do very few things, obviously either to rewax the lamination, which would cost u a boom, or to well, leave it as it is. after a few months, u will realised that even good new door aged under sun light pretty fast and the marking will be very faint.
