frostyapple
Feng Shui Advice Needed
I would suggest forumers to read and study the chinese star constellation first (chines's calender is part of it) before touching on those FS theories, simply all these theories and divination methods are based upon "the stars over the northern hemisphere".
Again, simply the chinese believe the movement of stars reveal the "will of God".
May start from the "3 great walls and 28 shou", follow by the "4 symbols" then the 24 jieqi. Try to understand how the chinese calender is based upon the solar and the lunar cycles. This is a true knowledge not superstition.
If its only harder to get rich, i'm still ok. Happiness and harmony within the family is the most important. As long as it does not harm the health of my 2 babies and my hubby, i think i'm happy. :)
Mine is also wide gaps.
To help readers understand what is Sha Qi:
Sha Qi is sharp, fierce, merciless Qi produced as a result of energies being focused by sharp corners, straight lines or narrow gaps, creating energy that moves aggressively and quickly.
Source:
http://www.joeyyap.com/fengshui/article.asp?ArID=416
Thanks Mae. Guessed my not considered narrow... I am now reading your blog. Interesting!
Only @ page 8 tough. Got to wait for my little monsters to sleep before i can do my own thing. :)
Hi, gal
Thank you for visiting my blog :bow: ...appreciate your stamina reading through the lengthy pages :jawdrop:
Its interesting! I like. I can see you dedication in supervising your reno and most importantly, your love towards your 3 boys.
I just copied your 'an chuan' method. :)
Dear Bepgof,
How do you apply these knowledge? Can share how to read the sky?
TIA!
Dear Bepgof,
TIA!
Lauer,
It's complicated. Chinese(northern hemisphere) has developed the above mentioned star constellation system for stars over the NH, there are star constellations over the southern hemisphere where ancient chinese could not "see" these stars.
Singapore is situated at 1 deg 26 min N, cannot "see" much of those NH stars, ( however, we can watch the 黄道十二宫)unless one is at latitude 23 deg N at least.....Need high enough mountain/building, dark-enough ambience, clear sky, then one can identify the constellation with naked eye.
At different months, the relative location of constellations become different. The most easy to identify one is 北斗七星 because of the U-shape with the hander. The hander points different direction at different months. So, with a reference point, say East, one is able to tell which month from the pointing direction of the hander.
This 北斗七星 is said to be the emperor's "cart"......Many stars' names are actually the names of roads....
Nowadays ppl where got time to study all these? They just interested in "quick fix" to solve problems. QF is targetted at symptoms but not the root causes, so.....到头来一场空。U can read the following links as beginning, if interested:
http://www.chinaname.cn/gleaning/gleaning-lifa.htm
http://www.lcsd.gov.hk/CE/Museum/Space/Research/StarName/c_research_chinengstarzone_b.htm
http://zh.wikipedia.org/zh/%E5%B2%81%E5%B7%AE#.E5.B2.81.E5.B7.AE
http://baike.baidu.com/view/868.htm#3
Edited by bepgof
