zero
Hi Zero,
I'm noob, but trying very best to evaluate the best option for the below:
Hob - Rinnai / Fujioh
Fujioh Cookerhood - FX900
Storage Heater - suggestion?
Built-in oven microwave - suggestiong??
Rinnai Gas Heater
REU-8CG
Made in Nagoya,Japan!
Uploaded with ImageShack.us
REU-8 CG Gas Water Heater
Do you often have to waiting for some time to get warm water for showering or to fill up the bath tub for a good stress-out soak? Well, with gas water heater, you will be able to enjoy instantaneous hot water anytime you need!
FEATURES
- No storage tank required
- Water is only heated on demand, no storage tank is required to heat and store the water.
- Instantaneous and continuous flow of hot water
- Just set the heater at your desired temperature. All you need is to turn on the tap and unlimited supply of hot water is available for your usage.
- Availability of hot water at multiple point
- Able to supply hot water to 2 shower points in 2 separate bathrooms concurrently.
- Ease of operation
- User-friendly in design and usage.
- Batteries operated, no electricity required
- Do not require any electric supply thus no wiring required.
- Built-in safety features
- Giving peace of mind to users with built in overheating protection, flame failure and incomplete combustion devices.
- Low running cost
- Gas tariff is typically lower than Electricity tariff by about 20%*, thus you save more using Gas.
- Compact in size
- Slim and compact design that fits well in the kitchen or yard space with no exhaust flue required
SPECIFICATIONS
Model: City Gas – Rinnai REU-8 CG
Colour: Metallic Silver
Dimensions: H 372 mm x W 290 mm x D 136 mm
Hot Water Capacity: (Raised 25 degree celsius)
Max. Hot Water Volume: 8.0 L/min (water pressure 50 kPa)
Min. Hot Water Volume: 3.0 L/min (water pressure 50 kPa)
Min. Operating Water Pressure: 0.20 Kgf/cm2
Automative Spark Ignition: Yes
Gas Consumption: 37.7 MJ/h
Weight: 5.7 (31) Kg(lb)
Call / Sms me for the best price.
Cheers
Jerome
92256638
Edited by zero
Hi Jerome,
Drop you a pm on LG fridge and washer plus Bosch oven. Wait for your reply. Thanks
Hi Flowerpot76,
Have pmed you.
Hear from you soon.
Regards,
Jerome
92256638
which brand is better? im noob on these cookers and hoods
Techno ,Turbo, EF or Rinnai?
Please advise
Have pmed you.
Regards,
Jerome
92256638
Hi Jerome,
Emailed you yesterday for a quotation. Appreciate your reply.
Thank you for the email, i have replied.
Hear from you soon.
Regards,
Jerome
92256638
Hi Zero,
Can you please recommended what is the most recommended & reasonable priced for following?
1. Hob with 3 burners (Like to have those that the parts can be removed for easy cleaning)
2. Hood
4. Built-in Oven
5. Electrolux Silent Vacuum ZUSG3900
6. Hitachi Fridge - R-SF42AM
7. Mitsubishi Fridge - MR-C46C, MR-BF43C
Regards
Joey
Hi Joey,
Pmed you.
Hear from you soon.
Regards,
Jerome
92256638
Hi Jerome, have PMed you a request for quotation and recommendation, look forward to your reply when you have the time. Many thanks in advance!
Hi Popartgirl,
Have Pmed you.
Hear from you soon.
Regards,
Jerome
92256638
Hi Zero,
2. Hood
4. Built-in Oven
Regards
Joey
Ariston Storage Heater - Made in Italy
Model: Ti Shape
Description
Ti-Shape 30
■Capacity: 30 Litres / 8 Gallons
■Power: 1.5 KW
■Volt & Phase: 230V x 1 Phase
■Installation: Above Sink
■Tank Material: Steel with Titanium Enamel Coated
■Triple Safety Device: Thermostat, Thermal Cut-off & Pressure Relief Valve
■Net Weight: 14.4 kg
■Warranty: 5 years on tank
■Dimension (H x W x D)mm 447 x 447 x 370
■Safety Mark Number: 032003-11
Price : $270
Call / SMS me to purchase a set now
Regards,
Jerome
92256638
Edited by zero
