Change The Kitchen Door To Sliding Door
Hi
Due to the limitation of space between the kitchen entrance & walking corridor, we would like to change the current swinging kitchen door to a sliding door instead to be wall mounted above & along the corridor area. Have checked with contractors and it's possible to do even turn over & change the door. :(
Please share and recommend any cheap & good sliding door contacts/ companies
thanks alot!
  • 1 month later...
i like this design. the door clicks & doesn't roll back. not sure if its expensive.
Sliding door was used as regular swing door could swing into the glass bathroom door.
Thus, client had chosen a Sliding door to avoid damaging glass door. Also, Veneer as also carefully select to match wardrobe Eco-series laminates.
Door veneer selected : Art No. 820 Recon Spring Ebony [New! 2010]
Lockset : Kolm Sliding door mortice with Square recess handle
Sliding Track : NISIN CLiQ system
http://picasion.com/pic28/923d74d90f51cfd19e7117782ccb9d9b.gif
When it comes to door gadget, Our crew in Contat are always very excited to test & share systems with everyone. NISIN CLiQ system is a revolutionary system, designed in Japan, that uses a special CLiQ mechanism to keep door securely close or open. This sliding system can solve common problems like air-conditioning leakage caused by gaps in sliding door when doors rolls back.
