convoy
Varnishing parquet floor
Guest our-home
Hi convoy
FYI, I called two parquet companies recently and was quoted $200+ to revarnish one bedroom floor (4-room flat). They didn't specify whether there was sanding and what type of varnish would be used.
In the end, my contractor is doing it instead, $180 for one bedroom floor + skirting - light sanding and revarnishing. Will need to check what type of varnish he'll be using though.
Just found out on 5 Sept from the contractor that the parquet floor below the window is badly damaged cos of constant rain-water seepage and may require machine re-grinding. One bedroom will cost an additional $250. Still thinking about it.
Edited by our-home
Can anyone advise where can i hire a belt sander to DIY the sanding of parquet?
If there are small holes in parquet, can i just apply those wood filler from those hardware store?
Thanks
Thanks
I have rented 2 water jet spray to clean roof top from cleaning company before
So you can try same strategy and call varnishing company to see whether can they rent you their polish machine.
That's what wood filler is for right? fill holes.
Edited by rendell
Hi everyone
I've once tried DIY a small area of Teak flooring in one of my master room fill
with dents. I must said it is hardwork plus backache with all the sanding, patching
and varnishing. However in the end I could not get same matt finish as the
rest of the Teak flooring. :bangwall:
I ended up calling the professional and was glad I've done so because my
Teak flooring which was only 12mm thick minus the inital sanding when my
Teak flooring was first installed I was left with less then 5mm of surface
thickness before it reach the tongue and groove of the Teak flooring. :jawdrop:
Hence the contractor said they have to be very careful to prevent oversanding.
Correct sand paper grit and equipment have to be use. Especially when using big
sanding machince which could easily eat up a lot of the surface thickness before
we even noticed. Well the Teak flooring is now serving a new owner who is also
fond of Teak flooring.
Hence unless you've experience in carpentry work or have done this before.
It is best to get professional opinion first before jumping to DIY. :sport-smiley-018:
MrWoodVarnish will be most happy to offer their professional services on parquet floor renovation, restoration n varnish works. F R E E pro advice n onsite survey ~ NO obligation. Cust Helpline: 1-800-Varnish
Thank you Mr Wood Varnish. u guys throughly Professional. One company that able to deliver 95% dust free sanding + one year warranty. my bad experiences w Contractors - subcon who not only did lousy job on my floor in previous condo, wood dust covered every inch of my walls, cabinets, ceilings n choke my aircon. Many many thanks :D
