WonderPig
Philips Led Downlights
Dear All, i happened to see lightings.com.sg selling LED Downlights.
Wattage range from 7 ~ 10W. Price range from 25 - 38. i was stunned that the pricing is quite competitive to their normal 14W phillips glass downlight.
Mai tu liao. This promotional offer will not last long. i bought over 20 pcs.
Visit their new branch at tradehub21 or blastier philips show room.
Peaceout!
Just a note,
Please do be mindful that Phillips LED downlights are fixed drivers. Means you will have to change the whole set when the lights go dead. As you might have known that as for LEDs, they live for a long time. Its the drivers usually give way earlier. As such choosing a LED downlight, that comes with separate module drivers is important.
next, do also check the Lux/Lumens of each LED downlight model. LEDs are ment to be calculated in Lux than by watts. Its only energy efficient, when you use lesser wattage but yet the brightness is on par with the recommended lux requirement for us to have good visibility.
Lux/Lumens is the calculation of brightness...
