YoMan
Condo Electrical Work Cost
For the electrical work for condo, anyone know if really cost that much? Or ID has put up the price?
Install new Lighting Pt = $55
Double Point Hack&Conseal = $90x8
Single Point Hack&Conseal = $85x5
1 nos of 2 way switches= $80x1
install 18 lighting fitting= $216
labor to change switches/socket casing for 25nos= $250
For condo it's more expensive because you need to hack and conceal the points therefore it costs more. HDB you can see the electrical trunkings that is why it is cheaper. :jawdrop: Light fittings at $12 per fixture looks okays same for the switches/socket casing at $10 per item.
Hope this helps.
:yamseng: ,
Mike
Hi were you happy with your electrician.
I need also an electrician for my condo to concealed and install new power socket in a bedroom.
If you can pm me the contact of your electrician.
Thanks
