YYChoi
Taking Flat Soon...
Have been reading quite a bit here. Finally, in about a month time, will be collecting my new 3-room flat in Punggol . About 67m2 only.
Just wanted to tap onto some advice here how much roughly should I put aside for reno if I am intending to do it minimally with all the basic stuff.
Also any recommendation on contractors?
Thanks,
Choi
3 Rooms should set aside $25K for wet work, 15K for carpentry, 15-20K for others like sanitary, kitchen appliances, sofa & TV etc
Total: 45-60K depending on how much things you want :good:
Hi, for recommendations on contractors, you could try Renotalk's "getting renovation packages". Quote your price and several companies may then contact you. http://www.renotalk.com/main/Renovation/Quotation/RenoQuoteRequestFormpg2.php
Hi advertising staff,
sorry that I post wrong place. ha..
Actually I wanted to get some "feel" from other home owners with maybe same size of flat as mine. Then mentally prepared. Sorry for the inconveniences.
Regards,
Choi
Hi Aldora89 and ganglong,
thanks! I will send you guys the floorplan once I have it scanned.
Yes, I opt to come with floor tiles.
Thanks,
Choi
Thanks,
Choi
most impt is have your own budget and see how you work around it.
i did my reno under 30k for 4 room 104sqm
