Pasting Laminate Onto Plywood Help
Anyone can recommend me where can I get someone to paste the laminates (formacia) I bought onto a customised size piece of plywood?
Thabks you
It is not difficult to paste Formica to plywoods.. you will need some tools such as formica cutter, D-clamps and some timber strips.. go buy a can of cement glue and a paint brush and some sand paper. Cut the plywood and formica to size. Clean the plywood and formica and then apply the cement glue evenly on both surfaces using the paint brush. Let dry the glue until it won't stick fingers, then stick both surfaces together. Using timber strips and D-clamp to apply pressure for good adhesion.. Here is one example..
http://www.wikihow.com/Put-Laminate-on-a-Counter-Top
If you want someone to do it for you, go to any wood working firm and get help.. plenty in Eunos and Ubi area
Edited by SKYJUICE123
  • 7 months later...
I believe this company sells Formica glue (contact adhesive), you can check out their website www.maxconenterprise.com
they are a plywood and timber supplier so i believe their glue is suitable for such use :D
cheers
  • 3 months later...
