gnolard
Wts: Brand New Honeywell Air Purifier 50250S
Brand new.
Self collect in Yishun.
SMS/ Whatsapp 98318217.
More information
Great for large rooms! Honeywell True HEPA air purifiers are the best choice for capturing airborne allergens. In fact, surveys show that more doctors recommend Honeywell air purifiers to their patients than any other brand.¹ It offers outstanding air cleaning performance with a HEPA filter. The True HEPA filter captures up to 99.97% of common airborne pollutants as small as 0.3 microns from the air passing through it such as dust, pollen, tobacco smoke, and pet dander. In addition, it also helps capture airborne viruses and bacteria.²
The Honeywell glass-fiber HEPA filter material helps remove airborne particles, viruses & bacteria without the use of chemicals or other treatments. It also includes an activated carbon pre-filter to help remove larger airborne particles and reduce common household odors. The patented 360° design maximizes efficiency.
The HEPA filter is easy to maintain and can be vacuumed to extend its life. The Intelli-Check® electronic filter indicator reminds you when to check the HEPA filter and when to replace the carbon pre-filter. This model is most effective for large size room up to 390 sq. ft.
3 powerful air cleaning levels
SurroundSeal® Technology helps minimize air leaks to ensure that the air passes through the filter, capturing particles as small as 0.3 microns
Replacement Pre-filter: HRF-AP1 or HRF-APP1
This air purifier is ARB Certified to comply with the federal ozone emissions limit.
The 50250-S True HEPA Air Purifier has been AHAM Certified for use in rooms up to 390 square feet. Its certified CADR ratings are:
250 for smoke
250 for dust
250 for pollen
1Based on 11/10 AQS survey results reporting 124 out of 172 (72%) of surveyed Allergists that recommend an air purifier to their patients recommend "Honeywell" air purifiers.
2From the air that passes through the filter. Overall particle reduction is dependent on many factors, including the amount of air processed, the pollutant type and the pollutants' introduction rate into the environment.
