angstygal
Protection Parquet Flooring
Hi there,
I have just moved into a Condominium apartment not long ago and I realised that the flooring in the bedroom is parquet flooring.
Is there any way to protect it such as putting a layer of laminate or something? And if there is, how much does it usually cost?
typically, there will be a layer of varnish on top of it.
if you are really paranoid, you may consider getting floor protector to serve as a barrier between the legs of chairs and the floor.
else normal use is quite ok.
after many years, you may also get contractors to re-polish and re-varnish.
