Home Photocatalyst Air Purifier Ionizer
Link: http://ninglife.com/collections/air-purifier/products/bomb-home-dehumidifer
What is a magiclight ball Ionizing Air purifier?
An air purifier is a household appliance that increases humidity (moisture) in a single room or in the entire house. There are point-of-use humidifiers, which are commonly used to humidify a single room, and whole-house or furnace humidifiers, which connect to a home’s HVAC system to provide humidity to the entire house.
Why should we need one?
You should keep a humidifier on hand in case you or a family member becomes ill. Humidifiers can ease breathing when you are congested as well as make coughs from colds or croup more productive to help you bring up phlegm. A humidifier can also help your nasal passages not dry out when you are sick.
The regulation of air humidity in the home is important to your health. Excessively dry air promotes dehydration of the eyes, skin, nasal passages and upper respiratory tract, leading to the possibility of microbial and viral infection. Moisture content in the air is heavily influenced by temperature, air circulation and amount of water vapor available.
Add some aroma diffuser oil, relax in the comfort of your own home by increasing indoor air moisture and create a healthier environment.
Suitable for use in:
Living rooms, study, bedrooms, children rooms and toilets.
Office air-conditioned environment, the bathrooms, tea and smoking rooms.
KTV, chess and card rooms, sauna bath centers, halls and guess rooms.
Product features:
The ultrasonic atomization technology is adopted. The water can be transformed into a fog without the additional of chemical agent and without heating. The air humidifier is novel unique and fashionable in design. Usable at home and at office space. The mist size can be adjusted freely. Humidification can be transformed by yourself. It can be reached super dust removal, sterilization, air purification effect through the photolysis of function and the release of a large number of negative ions. The effect of negative ions is refreshing. It can help user eliminate fatigue. Furthermore, it can both decorate indoor space and beautify the environment. The advantage of the product is saving the resources, and no need to replace parts, high efficiency and energy saving, zero noise.
Product advantages
Fine design and humidifying and bringing you beauty of vision
Building in safe equipment, automatically cut-off power when lacking water
With ultrasonic atomizer, saving energy, using for long life.
Convenient: Ultrasonic low voice design and with a switch, adjusting amount of mist as you need.
Product Specification
Model – BOMB
Brand name – Magiclight Ball
Coverage area – 20m2
Noise <36db
Technology – Ultrasonic atomization
Operating temperature – 5-400c
Power – 20W
Weight – 2kg
Voltage – 220V
Product size – 200mm*200mm*H215mm
Capacity – 1.5L
Humidification quantity – 250ml/h
Mist output – 1.5gal/day
Certifications:
CB, CE, CSA, EMC, EMF, ETL, GS, LFGB, RoHS, SASO, UL, URX
bomb_long.jpg?9654
Link : http://ninglife.com/collections/air-purifier/products/bomb-home-dehumidifer
Edited by exps
