Help With Bto Premium 5 Room Reno Works And Quotations!
Hey Guys,
I have compiled a list of items that I would need my ID/Contractor to do but... Am a complete noob (maybe that's why kena scam the last time). So what I have done is to list down what I need and what I want to do. If anyone has experience, please let me know if I'm overlooking anything, and if you've done something similar, please let me know how much your ID/contractor quoted you for the works they've done. Package or individual works also can. I just want a sensing on how much my budget needs to be, from HONEST and CARING people, rather than money hungry, blood-sucking unethical companies.
Lifestyle:
1. Family of 3+1 helper. My little darling is turning 2, so I'm thinking open spaces and un-cluttered house, bright.
2. Health conscious, only frying I will be doing is air-frying...
3. Mummy and Daddy works 5 days a week till 7pm, will need to install CCTV to monitor the little one
4. Will probably not be shifting out of the house for many years to come
IN A NUTSHELL:
1. Window Grills - if have budget invisible grills
2. Kitchen cabinet - IKEA anyone? Or will you still recommend getting the ID/Contractor to do? If have budget - Kompactop will be the first item i'll pump my money into. Backsplash necessary?
3. Electrical - Track lights definitely. Hubby thinks it's necessary to get more points than what is given by HDB. Suggestions?
4. Hacking of Kitchen wall - approx 2000x900
From RT quotations I saw seems like this is what I'll be needing in detail:
DESIGN WORKS
1 Consultation & Design
2 Space planning & 3D drawing
3 Product & Material proposal
4 On site supervision & project management
MASONRY WORKS
1. To supply & construct 50mm cement mortar kitchen cabinet base complete with matching HDB tiles
2. To supply & construct 50mm cement mortar fridge base complete with matching HDB tiles.
2. To supply & construct 50mm cement mortar washing machine base complete with matching HDB tiles.
PLUMBING WORKS
1. To supply labour and materials to extend copper piping @ existing HDB copper piping point for new kitchen sink position
2. To supply and lay conceal PVC piping for drainage area @ kitchen sink
3. To supply and lay conceal PVC piping for drainage area @ washing machine
4. To supply labour only to install storage heater c/w storage heater stainless steel piping extension for hot & cold
ELECTRICAL WORKS
1. To supply & run 10 nos. Of exposed lighting point @ living/dining.
2. To supply labour to install lightings (max of 15 nos).
3. To supply labour to connect 2 nos. of instant heater or 1 no. of storage heater.
4. To supply labour to install & connect 1 no. of door bell.
GLASS/WINDOW WORKS
1. Supply & install fix tempered panel glass to master bedroom toilet
2. Supply & install invisible grills for all windows in house
CEILING WORKS
1. To supply & install track lights for living room, corridor and kitchen.
2. To supply & install lights for 3 bedrooms
3. To supply & install ceiling fan for living room
HACKING WORKS
1. To hack and touch-up partial kitchen wall.
PAINTING WORKS
1. To supply & paint whole unit wall & ceiling with Nippon/ICI emulsion paint/ texture paint.
CARPENTRY WORKS
1. To design & fabricate L20ft kitchen cabinet using solid plywood in laminated finish c/w
2. Length 10ft kitchen worktop by Kompactop
3. To install Blum soft-close mechanism for all cabinates/drawers
MISCELLANEOUS WORKS
1. Chemical washing upon completion of work.
2. Laying of protection sheet before commencement of work.
Does anything not make sense? Will really appreciate if you have any views.
Am shortlisting a few IDs, please give me your thoughts on them as well
1. Rezt and Relaz
2. Sky-Creation
3. The wooden Platform
4. Fuse concept
5.SpaceSenseStudio
Hello,
With a little one, you will need more electrical points than what HDB provides.
If got rice-cooker on, feeding bottles in sterilizer, want to run blender, then how?
So please plan carefully.
My suggestion out of experience -- never sign contract without calculating each and every thing yourself. Make sure total mentioned in each column is correct.
Good luck for reno.
Hello.
I agree with ntr. for powerpoint is good to have more cause u will definitely need them. My House is done by this particular ID. I feel his service is good. and after comparing a few quotation. the quote he provide me is quite reasonable as well. if you need his contact, I can pm u. :)
Edited by Randy
Hi NTR - I know that too now :( Yes, will definitely insist on getting individual quotes and will crunch numbers carefully. Thanks for your advice on the electrical points too.
Hey Randy, Please do pm me your reno contact. And hopefully you're not employed by them in any way.
