delonchew
Quotation For Sengkang 4-room Premium
Hi all, pls advise whether the following quotes is reasonable, my hse is a premium flat at sengkang.
Masonry Works
Supply & construct kitchen cabinet base with matching floor tiles 1 Lot $180.00
Supply & construct fridge base with matching floor tiles 1 Lot $100.00
Supply & construct washing machine base with matching floor tiles 1 Lot $100.00
Supply labour to uplift sand, cement & materials to unit ( Haulage Loading )1 Lot $200.00
Total Amount : $580.00
Ceiling Works
Supply & install false ceiling @ foyer area 25 sqft $62.50
Supply & install false ceiling @ dining area 131 ft $327.50
Supply & install light box @ living area 60 ft $360.00
Supply & install false ceiling @ passageway to bedrooms area 21 sqft $52.50
Supply & install light box @ master bedroom area 20 ft $120.00
Supply & install false ceiling @ master bedroom area 55 sqft $137.50
Total Amount : $1,060.00
Painting Works
Supply & apply 03 coats of ICI Dulux or Nippon paint to all internal walls & ceilings( max. 8 colours )- $1,000
Total Amount : $1,000.00
Plumbing Works
Connect inlet & outlet piping for kitchen sink or washing machine 2 set $160.00
Supply labour to install accessories @ master bathroom 1 set F.O.C
Supply labour to install accessories @ common bathroom 1 set F.O.C
Supply labour to install storage heater 1 nos $100.00
Supply labour to install kitchen sink, hob & hood 1 set F.O.C
Total Amount : $260.00
Aluminium Works
Supply & install powder coated sliding windows @ service yard area c/w 03 way track & coloured glass ( max. height 4.5ft ) 31.5 sqft $472.50
Total Amount : $472.50
Glass Works
Supply & install 10mm thick clear tempered glass sliding door @ kitchen entrance 1set $780.00
Total Amount : $780.00
Miscellaneous
Supply & lay protection sheet 1 Lot $100.00
Clean up whole unit with chemical 1 Lot $200.00
Total Amount : $300.00
Custom Made Build-in Furniture - All laminates from Germany or Italy with solid ply wood
Living & Dining Area
Design & fabricate full height shoe cabinet in laminate finish 3 ft $660.00
Design & fabricate ledge settee in laminate finish c/w conceal metal bars 2 ft $100.00
Design & fabricate feature wall @ household shelter area in laminate finish 8 ft $1,280.00
Design & fabricate feature wall @ Tv area in laminate finish 6 ft $960.00
Design & fabricate suspended Tv / players console in laminate finish c/w glass panels 6 ft $720.00
Total Amount : $3,720.00
Master Bedroom Area
Supply & construct false wall for walk-in wardrobe with partition board 5.5 ft $220.00
Design & fabricate sliding or bifold door in laminate finish c/w heavy duty top track,
glass panels design 3 ft $645.00
Design & fabricate full height walk-in wardrobe with polykem internal 11 ft $2,090.00
Design & fabricate feature wall @ Tv area in laminate finish 4 ft $720.00
Total Amount : $3,675.00
Master Bathroom Area
Design & fabricate suspended vanity cabinet in laminate finish 5 ft $450.00
Supply & install wall to wall bevelled edge mirror 5 ft $200.00
Design & fabricate light pelmet in laminate finish 5 ft $220.00
Total Amount : $870.00
Bedroom 2 Area
Design & fabricate full height wardrobe in laminate finish c/w swing doors 6 ft $1,320.00
Total Amount : $1,320.00
Bedroom 3 Area
Design & fabricate day bed in laminate finish c/w cushion 1 Lot $3,080.00
Design & fabricate display cabinet in laminate finish c/w glass doors 3 ft $840.00
Design & fabricate ledge as study table in laminate finish 6 ft $240.00
Total Amount : $4,160.00
Kitchen Area
Design & fabricate top & bottom kitchen cabinet in laminate finish c/w 04 sides ABS trimming swing doors, chioces of drawers, cuttlery tray, 02 pcs of glass panels & designer handles 33ft $3,300.00
Supply & install stainless steel dish rack with hydralic system & glass panel 3ft F.O.C
Supply & install solid surface worktop for kitchen cabinet 15ft $1,050.00
Total Amount : $4,350.00
Common Bathroom Area
Design & fabricate suspended vanity cabinet in laminate finish 5ft $450.00
Supply & install wall to wall bevelled edge mirror 5ft $200.00
Design & fabricate light pelmet in laminate finish 5ft $220.00
Total cost; $23,417.50
Edited by homeangel120
