3d Software For Hdb
Hilo, the textbox\place to enter value will only be enabled when you select a tool that use it.
For example, when you select the Line tool, the bottom right textbox will be enabled and it will be displayed with a label call Lenght. :bangwall:
When you right click and hold, you will notice that there is a color of color when you shift your mouse arround. This is an indication of axis change. :)
I also have the same problem i could not enter the value i want on the value box, it merely show how long is the line i draw which is difficult with line draw to get exact value. Can anyone advise?
  • 4 months later...
Hi, can i check.. this Goggle Sketch Up is for MAC OS only? Tks!
