jimmya
Is This Quote Cheap And Reasonable?
Hi jimmya, where u buy at JB? Pelangi plaza which shop. Can take pictures n show me the furniture u bought.. Wanted to buy too sg too expensive. Do pm me thanks
Do advice.
Construct fridge base - $150
c/w Blum Hinges
c/w Color polygon
- all doors in ABS Trimming
- 1 set of cultery tray
Chemical Washing - $200
Total $22235.
Do advice and help me out.
thanks
Hi Jimmy
Can pm me ID contact? Thanks
Guest Sen Wei Chua
Hi Jimmya Pls email me @ chuasenw@singnet.com.sg your id. I have a very small budget and need is honest id and contractor. Thanks
