What The Difference Between Mitsubishi Inverter/mitsubishi Starmax/mitsubishi Heavy Industrial?
Hello all,
Can someone pls explain to me the difference?
I am interested in getting system 4.. but am unsure which is better..
Thanks a million!
Hello all,
Thanks a million!
We call ME and MHI, both are the Thailand made.
But quality wise may ME slighly better than MHI.
The outlook can't define, once you remove out the front cover and realize the design will be slighly cheap like china made
Go for ME you won't regret lah.
Thanks KimSim..
ME means?
Sorry if i ask stupid qns before first time doing house reno...:)
another qns is on the BTU etc.. how do i chose or know if the capacity is good enough?
my house is 4room BTO.
Thanks KimSim..
ME means?
ME stand for Mitsubishi Electric
Just don't choice smaller BTU such as 18k BTU for 3 bedroom, I guess from Daikin & MHI had it packaged only, From ME will be package on 3A28VA or 4A28VA & 4A38VA for outdoor total BTU.. 28 meant = 28k BTU.
Can refer my personal info too
http://www.kimrovacstore.com/home-air-conditional-2015.html
The guide for room can refer here
http://ahyi.weebly.com/tips--info.html
Thanks
THanks once again!
So in short, can i say that Mitsubishi has 2 types basically.. 1 is MHI & ME?
ME refers to starmax model as well as Mitsubishi Inverter?
Betweem Starmax and inverter, which i better?
Thanks
THanks once again!
Same company name, but different division and products, but if you need more info Budget then go with MHI only, if you wanna enjoy more top class then ME will do and last longer for parts.
Otherwise just look at others brand
  • 7 years later...
Nowadays you can find different kinds of Frequency Inverters on the Internet. But I make such serious purchases only at trusted stores. Choosing the right inverter for your needs is an important decision. We are very dependent on our power sources. In many cases, it can power an entire home or business, including lights, refrigerator, TV, computer and other expensive equipment. When choosing an inverter to meet your needs, it is important to consider the type of loads you have.
