Anyone Can Advise On The Quotation
Anyone can help to advise on the below quotation?
Hacking Work
Hacking of existing kitchen cabinet inclusive
Hacking of existing toilet bowl & basin inclusive
Hacking of existing wall & floor tiles at 2 toilet inclusive
Dismantle & dispose of existing toilet door inclusive
Hacking of existing wardrobe at 2 bedroom inclusive
Hacking of existing shoe cabinet **** inclusive
Opening new entrance at master toilet inclusive
$2,800.00
Living & Dining
Design,fabricate & install (L)5ft full high shoe cabinet in solid-ply finish with high grade $1,250.00
EDL 2015 laminate at main door entrance
Kitchen
Supply material & lay chemical cement screeding at wall $380.00
Supply labour & material to plaster smooth at kitchen wall $950.00
Supply material & lay pre pack cement screeding at floor $952.00
Laying of 3 in 1 water proof screed 2-Step K-11/104 Water Proofing Membrane $350.00
Supply & lay 300mm x 600mm heavy duty non-slip homogenous floor tiles at floor. $1,904.00
> est.238sqft inclusive of wastages
Supply & construct cement mortar kitchen cabinet base finish with side tiling work. $450.00
Supply & construct cement mortar washing machine base finish with full tiling work. $150.00
Design,fabricate & install (L)30ft top & bottom kitchen cabinet in solid-ply finish with high grade $4,500.00
EDL 2015 laminate comes with wooden frame
> 1 no.s of 2 tier dish drainer FOC
> 1 no.s of cultery tray FOC
> 1 no.s of sand-blasted glass panel FOC
Anti slam SOFT CLOSING mechanism for all kitchen cabinet doors FOC
Anti slam SOFT CLOSING mechanism for kitchen cabinet drawers 4 set Blum system original track FOC
Custom-made & install est.(L)14ft granite at kitchen cabinet top C/w Backslash. $1,680.00
Design,fabricate & install (L)5ft counter top with cabinet in solid-ply finish with high grade $1,000.00
EDL 2015 laminate come with wooden frame
Supply & install 1 set 3ft x 7ft 10mm clear tempered glass siliding door at kitchen entrance $650.00
Supply & install 1 set rubbish chute $190.00
Master bedroom
Design , fabricate & install L-shape est. (L) 10ft full high casement wardrobe in solid-ply finish with $2,500.00
hign grade EDL 2015 laminate at master bedroom .
Design , fabricate & install laminate at wardrobe backing in solid-ply finish with $700.00
Master Bathroom
Supply material & lay pre pack cement screeding at wall $820.00
Supply & install 300mm x 450mm glossy design / 2 tones ceramic tiles wall till ceiling height $1,640.00
> est.205sqft inclusive of wastages
Supply material & lay pre pack cement screeding at floor $250.00
Laying of 3 in 1 water proof screed 2-Step K-11/104 Water Proofing Membrane $280.00
Supply & lay 300mm x 300mm heavy duty non-slip homogenous floor tiles at floor. $480.00
Supply & construct 1 nos shower kerb finish with tiles $180.00
Supply & install 1 set 10mm clear tempered glass shower screen , 1 fix panel $250.00
Supply labour & material to make good damage area at new entrance $280.00
Supply labour & material to seal up existing door entrance using 63mm hollow block $400.00
Common Bathroom
Supply material & lay pre pack cement screeding at wall $896.00
Supply & install 300mm x 450mm glossy design / 2 tones ceramic tiles wall till ceiling height $1,792.00
> est.224sqft inclusive of wastages
Plumbing Works
Supply & install stainless steel cold water piping for whole unit $680.00
Labour to install 2 set of bathroom accessories. $120.00
Laying of 2" conceal drainage pipe for kitchen sink $40.00
Laying of 2" conceal drainage pipe for washing basin 2 set $80.00
Labour to install 1 set of Kitchen Sink c/w Tap $90.00
Labour to install 2 set of instant heater at 2 toilet $300.00
Labour to install 2 set toilet bowl $180.00
Labour to install 2 set washing basin and tap $160.00
Door Works
Supply & install 2 set 3ft x 7ft aluminium slide swing door at 2 toilet $780.00
Painting Works
Painting of whole unit using Nippon Original Paint: ( 5 color ) $1,450.00
> all internal wall with NIPPON vinilex 5000 Paint
> all internal ceiling with NIPPON Matex or SKK White Paint
> all pvc pipe with NIPPON Bodelac 9000 Paint FOC
Miscellaneous Works
Haulage fee $350.00
Corrogated paper for (Protection) $350.00
Chemical wash upon works completion $350.00
HDB Renovation Permit fee FOC
