shibumi 1 Report post Posted September 15, 2015 Hi fellows, I'd shifted in for a few months. While shifting furniture around &/or installing other small furnishings, I caused some damages to my walls & ceilings paint job. My ID kept some of my leftover paint around. May I know: Qn1: if it is possible to use a water-colour brush (yes, those small-tipped ones used for art & craft) to directly paint over these areas?: (Exhibit A): around 10-cent coin diameter (Exhibit B): half a palm size Cause from what I see on YouTube most of them tutorials sand off a lot of the area surrounding the damaged spot, then paint a base white, then paint a few more coats of the desired colour paint. But as you can see in my exhibit, my "damaged areas" so small only... Qn2: may I know how to determine if my leftover paint is in a ready-to-use mix, or need to mix with some other chemicals before using? Quote Share this post Link to post Share on other sites
w7_lee 11 Report post Posted September 16, 2015 Using water color paint brush is no problem.From your 'very clear' picture, the wall was painted using rollers, so you will see the brush stroke if you use paint brush.But you should 1st remove the peeling part. I would just use a rough cloth and wipe the damage area, the peel part should drop off. Quote Share this post Link to post Share on other sites
shibumi 1 Report post Posted September 16, 2015 ...From your 'very clear' picture...Wait, actually do you mean I should provide a much clearer picture? I don't get your quotation marks. Quote Share this post Link to post Share on other sites
w7_lee 11 Report post Posted September 17, 2015 Don't misunderstand, I just meant the pictures (especially the first) are very high resolution. So looking at them, I could image seeing the brush stroke after the touch up.It should not be too obvious unless you are looking at it in the same high resolution. Quote Share this post Link to post Share on other sites
shibumi 1 Report post Posted September 26, 2015 Anyway I decided to go ahead to use an art & craft brush to rectify the spot damages. The brush I'd used this not the type with black strands; it's also not the calligraphy type. It's the type with white strands that are so stiff that you need to soften it with warm water before 1st use.Anyway, let's see some results. First, some small spots of my bedroom wall that got peeled off due to some silicon stoppers (you know those clear rubbery ones you stick on drawer doors to dampen slamming) being pressed on it for a long time (& then pulled away).This is the before:& this is the after:& from a distance (I included the manual so that the camera has a reference distance to focus on):Another area; this is the before:& this is the after (immediately after painting):http://i.imgur.com/WFErtJd.jpg& this is the after (after some drying time):http://i.imgur.com/XupAQqR.jpgOverall, for the effort & time I expended, I'm pretty pleased with the result. I know the proper way is to sand off, re-prime the area, then paint multiple thin coats, but...the choice to pursue which approach is up to individuals. Quote Share this post Link to post Share on other sites
shibumi 1 Report post Posted September 26, 2015 For some reason the last 2 images in the post above is given the wrong link; so here they are (embedded), in the same order as above: Quote Share this post Link to post Share on other sites
