Installing Whirlpool 808 Acm Hob. Advise Needed
Hi all,
I have just bought a whirlpool acm 808 induction hob. 7200w, 31.3a. Was told that to install a 30amp switch by e seller. However, my electrician say that hdb max is 40a, best not to have a switch more than 30a. Should i change the hob?
Cooking zones
  • The front left zone: Induction
  • The diameter of the front left zone: 145 mm
  • Power front left zone / Booster: 1200-1800 W
  • Rear left zone: Induction
  • Diameter of the rear left zone: 210 mm
  • Power rear left zone / Booster: 2200-3200 W
  • Right rear zone: Induction
  • Diameter of the rear right zone: 180/230 mm
  • Power rear right zone / Booster: 1800-2200 W
  • Front right zone: Induction
  • The diameter of the front right zone: 180/230 mm
  • Power front right zone / Booster: 1800-2200 W
Specifications
  • Maximum power input: 7200 W
  • Voltage: 230 V
  • Frequency: 50-60 Hz
  • Recommended network connection: 400V 3N ~ V
  • Power consumption in standby mode (2010/30 / EC): <1.0 W
  • Energy consumption in off mode (2010/30 / EC): <0.5 W
  • Dimensions (HxWxD): 56x580x510 mm
  • Packaging dimensions (HxWxD): 140x670x590 mm
  • Aperture dimensions (HxWxD): 560x490 mm
  • Mass: 12.5 kg
  • Weight with packaging: 13.5 kg
Is there any other ways I can utilize it in HDB?
Edited by tianzui
