VeryDulan
(Looking for Help) L-Box with downlights
First time handling renovation on my own, need some help to clarify some details as follows;
1. Do i need to get electrician to standby the open wirings to all the downlight points before i get the L-box installer to come in? What should the sequence be?
2. Do i engage electrician to open hole in the L-box to install the downlights for me? Otherwise what kind of contractor do i need to engage?
3. Do downlights come in different sizes? Do i have to buy the downlights and take the dimensions first before calling in the electrician and the ceiling contractors?
normally it goes like this:
lay wiring first... the light points will have wire dangling down
lay L box/false ceiling.
electrician will open the holes.
best is u brought along the actual lights so that the electrician can do its own measurement
Very useful info for all :)
You will also need to plan for the switch. Does 1 switch turns on all light or different switch turns on different (section) lights. And do you need 2 way switch etc. Where will the electrician tap the electricity, will it overload... The electrician should plan for you but still good to know.
Just sharing as I am also in the midst of finding contractor to do L Box and Cove light.
