happywork
Assembly-type construction
Assembly-type construction, good overall. Is an assembly-type construction, itself three-in-one structure, board and board connected into a whole, the impact resistance is 1.5 times the normal masonry; polystyrene particle sandwich structure, no deformation, steel structure anchoring, wall strength High, the overall seismic performance is higher than ordinary masonry walls many times! Moisture, water, noise. Polystyrene sandwich panels can be used without any water-resistant finishes, cement bonded into a pool filled with water, the back of the wall can be kept dry, without leaving any traces of moisture in the condensate will not appear Beads Can be used in kitchen, bathroom, basement and other wet areas. In addition polystyrene fiber sandwich panel surface of the cement fibers and the internal composition of the material has a good sound insulation. Insulation, insulation polystyrene particles sandwich board composition of the material has a good thermal insulation function, with the thickness of the composite board is a brick wall thermal insulation capacity of 10 times more! Indoor temperature can make more comfortable. Can be hung. Polystyrene particle board can be directly nailed or bolted on the expansion of heavy objects, such as air conditioners, single-point hanging capacity of 45kg or more; and the wall panel surface smooth and will not produce dust, paste directly Tiles, wallpaper, wood veneer and other materials for finishes. Second, the disadvantage of lightweight composite wall materials. Of course, it has an inevitable disadvantage - you can not afford it! Therefore, it can only be used to support the frame structure or steel structure house, can not be used in brick building, which must be noted.
bamboo hardwood flooring clearance
balcony dorchester style railing
cheap vinyl deck railing at menards
indoor outdoor interlocking tile
