Wooden Cabinet or Aluminium Cabinet
I saw there is this new thing: aluminium cabinet! Looks really feasible because not like wood will rot and termites. The finishing also very nice with glass finish. I'm thinking whether I should change my kitchen cabinet.. Any suggestions?
eh. Didnt know got this type of cabinets? more expensive than wooden cabinets? My bro in law last time got see but never got a chance to buy liao.
ya, i also just found out about this! ya i heard its slightly more expensive than wooden cabinets, but at least worth it leh, can use very long!
Yes, you should consider to change it. My aunt has a terrible experience with wooden cabinet. Just only 1 years, the wood cabinet will start to have some smells, and also have the white dots on the wood. We suspect is a termite's eggs. End up they decided to replace it with an aluminium cabinet.
 not much difference in price. but you have more pros than wooden cons.
especially if wood will spoiled within 2years if contact with water.
  • 5 years later...
Some advice regarding wooden versus aluminum cabinets: which one would be best for your kitchen?
Selecting the appropriate material for your cabinets is one of the most crucial decisions you will make while organizing a kitchen makeover. Both hardwood and aluminum cabinets are somewhat common choices with special benefits and drawbacks. We shall discuss the main variations between wooden and aluminum cabinets in this post so that you may choose the one ideal for your kitchen.
Aesthetic Pleasure
Wooden cabinets are prized because of their classic and ageless appearance. From traditional to modern, they provide a natural warmth and elegance that would accentuate any kind of kitchen design. Rich wood textures and grains will give your kitchen individuality and elegance. Furthermore, wooden cabinets can be customized to fit your own taste by means of several treatments and dyes.
On the other side, aluminum cabinets give a modern and elegant look. Their association is sometimes with contemporary, industrial kitchens. Aluminum's simple lines and shiny finish will help your kitchen seem stylish and modern. Aluminum cabinets provide design flexibility by being available in a spectrum of colors and finishes.
Maintenance and durability
Although wood is a strong material, it needs regular upkeep to maintain looking great. Moisture can cause warping, swelling, and over time cracking in wooden cabinets. They must also be kept free from pests including termites. Maintaining the look and lifetime of wooden cabinets depends on regular cleaning and sporadic refinishing or sealing. With correct maintenance, though, wooden cabinets can last for decades.
The great durability and inexpensive maintenance of aluminum cabinets are well-known. Perfect for humid surroundings like kitchens, they are impervious to moisture, rust, and vermin. Aluminum resists daily wear and tear without losing its shape or finish; it does not warp or crack. Cleaning aluminum cabinets just calls for a moist towel and is easy. Their durability qualifies them as a sensible option for hectic homes.
Value vs Cost
Wooden cabinets can range greatly in cost based on the type of wood and workmanship. Though more costly, high-quality hardwoods including cherry, maple, and oak can enhance the value of your house. Because of its timeless charm and durability, wooden cabinets are thought of as long-term investments. They can improve your house's whole resale value and look.
Aluminum Cabinets: Usually more reasonably priced than upscale oak cabinets are aluminum cabinets. They provide a reasonably priced fix without sacrificing durability or flair. Reduced maintenance needs also translate over time into financial savings. Although aluminum cabinets might not be as classic as wood, their modern appearance nonetheless adds value—especially in modern house designs.
Environmental Effects
Wooden cabinets' environmental effect relies on the source of the wood. Responsibly obtained and sustainable wood can help to lower environmental impact. Still, the usage of non-sustainable timber supplies and deforestation might have bad effects on the surroundings. Selecting wood certified by environmental agencies is crucial to guarantee ethical procurement.
Aluminum cabinets are a green option since aluminum is a very recyclable substance. When aluminum cabinets are produced, less environmental damage results than that from deforestation. Furthermore less energy is used in recycling aluminum than in obtaining and processing raw resources. Thus, especially if recycled metal is used, aluminum cabinets can be a more ecological choice.
Conclusion
Although they are appropriate for different kitchen designs and purposes, hardwood and aluminum cabinets offer different advantages. With correct care, wooden cabinets may be a wise long-term investment and have classic elegance. Modern kitchens and hectic homes would find aluminum cabinets perfect since they offer a contemporary look, great durability, and low upkeep.
Think on the general design of your kitchen, your preferred maintenance schedule, and the environmental impact of your selection while deciding what to do. read on AmpQuartz cabinet blogs on wooden kitchen cabinets.
Considering the advantages and drawbacks of every material will help you select the cabinets that best suit your way of life and improve the utility and appearance of your kitchen.
