3i Resale Quotation
Hi All,
Need advice here whether the quotation given is ok? No ID, just contractor.
BATHROOM/WC
SUPPLY LABOUR TO SHIFT BASIN TO BATHROOM (INCLUDE INLET/OUTLET PIPES) $180
SUPPLY/INSTALL 2 SETS OF ALUMINIUM/ARCYLIC BI-FOLD DOORS FOR BATHROOM AND WC $440
SUPPLY/CONSTRUCT NON-SLIP FLOOR TILES FOR BOTH TOILETS (<$3 PSF) $580
WATERPROOFING FOR BOTH TOILETS TO BE CARRIED OUT $200
SUPPLY/CONSTRUCT 2 TONES FULL HEIGHT WALL TILES FOR BOTH TOILETS (<$3 PSF) $1,680
KITCHEN
SUPPLY/OVERLAY HOMOGENEOUS FLOOR TILES (INCLUDE REMOVAL OF EXISTING RUBBER TILES) $680
(NOTE: ONLY 1/2 PORTION)
DEMOLITION OF EXISTING LOW WALL AND WINDOW AND MAKE GOOD ON AFFECTED AREA $350
DISMANTLE AND DISPOSAL EXISTING KITCHEN CABINET (ONLY A SMALL PORTION) $90
PLASTERING OVER EXISTING FULL HEIGHT WALL TILES WITH PAINTING FINISH $980
TO SUPPLY/RAISE WITH POLYFOAM TO RECEIVE LAMINATED FLOOR (1/2 PORTION) $90
SERVICE BACLONY
SUPPLY/OVERLAY HOMOGENEOUS FLOOR TILES (<$3PSF) $580
DEMOLITION OF EXISTING SINK AND STOVE CONCRETE SUPOORTS AND MAKE GOOD ON AFFECTED AREA $290
WINDOWS AND GRILLES
SUPPLY/INSTALL SLIDING WINDOW AND GRILLES FOR LIVING HALL AND BEDROOM 2 $670
LIVING HALL
SUPPLY/INSTALL LAMINATED FLOORING WITH SKIRTING FOR LIVING HALL & 1/2 KITCHEN(SUPREME) $1,060
DEMOLITION OF EXISTING SKIRTING WITH SMOOTH FINISH FOR LIVING HALL $120
SUPPLY/INSTALL 1 NO.FEATURE WALL MIRROR AT DINING HALL (4 X 6)FTS $590
PLASTERING OF EXISTING CEILING FOR LIVING HALL AND 1/2 KITCHEN $320
BEDROOMS
SUPPLY/INSTALL LAMINATED FLOORING WITH SKIRTING FOR 2 BEDROOMS (SUPREME OR KRONOTEX) $1,150
DEMOLITION OF EXISTING SKIRTING WITH SMOOTH FINISH FOR 2 BEDROOMS $150
PAINTING
PAINTING OF WALL/CEILING WITH ICI PENTALITE OR NIPPON 5000 FOR LIVING HALL AND 2 BEDROOMS $690
(ADD $180 IF PAINTING OF CEILING FOR TOILETS, KITCHEN AND SERVICE BALCONY)
WHOLE HOUSE AND GENERALS
DEBRIS REMOVAL & HACKING OF FLOOR TILES AND WALL TILES AS PROPOSED $780
HAULAGE OF SAND SERVICE TO BE CARRIED OUT $750
SUPPLY/LAY CURROGATED BOARD TO PROTECT NEW FLOORING (INCLUDE DISPOSAL) FOC
WHOLE HOUSE CHEMICAL WASHING AND CLEANING FOC
SUPPLY/INSTALL 1 NO. WROUGHT IRON MAIN GATE C/W LOCK $460
SUPPLY/INSTALL 1 NO. SOILD MAIN DOOR C/W LOCK AND VANISHING $480
ELECTRICAL BREAKDOWN
LIGHTING POINT=$30(INCLUDE SWITCH) ,SINGLE POWER SOCKET=$45
DOUBLE POWER SOCKET=$55 ,TEL POINT=$55 ,SCV POINT=$95 ,HEATER POINT=$95
INSTALL LIGHT=$8 ,AIR-CON POINT=$95 ,RELOCATE POINT=$25 ,CONSUMER CONTROL UNIT(DB)=$280
Thanks in advance, Jen
Hi All,
BATHROOM/WC
For inlet and outlet pipings make sure it wont be out of shape when being shift from one place to other.
For non-slip floor tiles what is the tiles provided? Homogeneous or cermic?
KITCHEN
Please make sure that current ties are in good condition before overlay. As will cost the tiles poping in furture years and will cost a bigger hole in ur pocket.
SERVICE BACLONY
WINDOWS AND GRILLES
LIVING HALL
For laminated flooring, normally all skirtings will be included in the package. Wont be extra charges for demolition of existing skirting. :sport-smiley-004:
BEDROOMS
same as above.
PAINTING
hmmm.. normally all paintings will include all area... wont have extra charges for it.
For the chemical and cleaing make sure they did both if u engage with them. As they will assme that chemical wash and cleaning will be together.
Please make sure that they will meet up to PUB standard. Im not sure that ur wirings are conceal or not.. :sport-smiley-004:
Hope it helps...
Hope it helps...
Hi Shawn,
Thank you so much for your PM. Do you think the cost will be higher if I engage an ID for doing the same thing?
Refer to the quotation:
- For non-slip floor tiles what is the tiles provided? Homogeneous or cermic? CERAMIC
- Contractor said no problem in laying over the wall.
In general, do you think the quotation is reasonable?
Thanks again :sport-smiley-004:
Jen
Hi Shawn,
Jen
They will indeed charge slightly higher. ID will indeed will be better. At least when things happens you can just find ID. Dont need to go and find contractor and argue with them. ID will settle it.
But dont forget material and quality plays a part too. Each cents counts. :sport-smiley-004:
There are indeed some hidden cost there as i had mention about the skirting issues. Well still will be better to hunt for a few quotes no harm.. :sport-smiley-004:
Good luck in ur findings... :bangwall:
Edited by Devilaz
