cornetto
Sofa & Divider
Hello Mr Chong,
Would like to consult you on certain matters.
1) Our sofa is not against a solid wall & is in fact, under a beam. however, when we sit, due to the thickness of the cushions, our heads are not directly under the beam. is this okay?
2) We made a half height cabinet abt 3m away from the main door. now it looks like a divider & many pp are telling us tt it should be constructed to full height to prevent qi from passing thru. however, our main door is not facing window or any back door (windows are at the right hand side when coming in). does this matter?
have attached a pix of the layout for your reference. hope it is clear.
Thanks a lot for your help.
Hello Mr Chong,
Hello cornetto
My sofa is also under a beam.....this should answer you question permanently :) (Btw, my explanation is in other post)
Why prevent Qi from passing through? You should allow Qi to permeate every part of your house. Like you said, there is no window nor back door. Don't worry!!!
