Kkg 0 Report post Posted January 13, 2020 I wanted vinyl flooring for my kitchen, living hall and bedrooms. My cement screed was done at a lower height, shortage abt 7mm - 10mm from my kitchen existing tiles. I was unable to have my vinyl levelled between kitchen and living hall. They have to put on an pvc cap between kitchen and living hall. Is there anyway to fix this? I was expecting the whole flooring to be of the same level. Share this post Link to post Share on other sites
snoozee 99 Report post Posted January 13, 2020 Normally kitchen will be at a lower level than living room since it is a wet area so as to prevent water from flowing to living room in case of washing the floor. Only way to fix is to add more screed to same level as living room Share this post Link to post Share on other sites
Kkg 0 Report post Posted January 15, 2020 My floor contractor say cannot screed anymore as the screed might crack. How true is this? Share this post Link to post Share on other sites
snoozee 99 Report post Posted January 15, 2020 screed manufactures will have recommended thickness for application of the screed. if too thick it will crack. Share this post Link to post Share on other sites
Kkg 0 Report post Posted January 15, 2020 Just to clarify too thick or too thin will crack? I need abt 7mm to 10mm of addition height. Share this post Link to post Share on other sites
snoozee 99 Report post Posted January 15, 2020 both. too thin will not provide enough strength to the screed. too thick may also crack due to the uneven drying of the screed. you can search online for data sheets from screed manufacturers and they normally recommend thickness of 10mm to 40/50mm. if need more then usual case is pour concrete to top up then apply screed. of cos if you insist on doing it and am willing to bear any consequences of it and indemnify your contractor I don't think he will not do it if he is paid. it's just that if anything happens, he may tell you, "I told you so" Share this post Link to post Share on other sites
